Band saw blade bearing adj
Forum topic by hkmiller posted 09-30-2018 12:30 AM 300 views 0 times favorited 2 replies Add to Favorites Watch
View hkmiller's profile
hkmiller
180 posts in 686 days
09-30-2018 12:30 AM
Should the back of blade be resting on the bearing when there is no saw blade pressure (I.e. not cutting)
-- always something
2 replies so far
View jamsomito's profile
jamsomito
457 posts in 1030 days
#1 posted 09-30-2018 12:33 AM
My understanding is it should be the thickness of a piece of paper away… so as close as you can get it without touching. The back bearing is a tricky one though as the blade usually has a step in it at the weld. Some say to grind this down with a file on the back of the blade the first time you use it. It will help prolong the life of your bearing and run smoother too.
View TheFridge's profile
TheFridge
10859 posts in 2090 days
#2 posted 09-30-2018 03:39 AM
it Should touch the bearing only with pressure from the blade. Very light pressure at that.
