Grizzly G7947 drill....how well would a mortising attachment work?
Forum topic by Poplarguy posted 09-29-2018 08:56 PM 522 views 0 times favorited 2 replies Add to Favorites Watch
View Poplarguy's profile
Poplarguy
42 posts in 499 days
09-29-2018 08:56 PM
How well would a mortising attachment work on this drill press and how well would the drill/mortising attachment work vs a stand-alone mortiser of equal HP?
Drill is 1 hp, I have a larger drill press table with fence built on it.
2 replies so far
runswithscissors
3081 posts in 2634 days
#1 posted 09-29-2018 11:59 PM
I tried that, and found it a disappointing experience. The problem isn’t the DP’s horsepower—you’re usually not driving more than a 1/2” auger (often less) into the wood—it’s the insufficient downward force you can impart to the chisel. Also, the kit I used had inadequate hold downs for when you withdraw the mortising chisel. Very frustrating.
Actually, that last part is typical even of dedicated mortisers. I modified mine (Delta bench top) with toggle clamps which helped a lot.
Poplarguy
#2 posted 09-30-2018 12:46 AM
That was what I’m kinda gathering from the WWW, it’s good to hear more qualified input here. Thank you.
