Tell me about your aftermarket 14" bandsaw tire experience
Forum topic by Charlie H. posted 09-29-2018 12:52 PM 1499 views 0 times favorited 10 replies Add to Favorites Watch
View Charlie H.'s profile
Charlie H.
395 posts in 1260 days
09-29-2018 12:52 PM
I have a Jet JWBS-14OS bandsaw.
The original tires failed after 8-9 years.
At that time I bought Carter replacement tires which are now maybe 3 years old.
The Carter tires were too narrow for the wheels on day one but they fit the diameter very tightly and after using forceful persuasion to get them centered on the wheels the saw worked fine.
The widest blade I use is 1/2” so I figured the Carter tires were wide enough.
The tires have become loose on the wheels to the point they can be moved side to side between the wheel lips quite easily with one finger.
The saw is still working fine but the tires are growing and are going to become a problem.
I don’t really want a repeat of the original tire failure that resulted in the tire smoking and coming partially off the wheel.
When the Carter tires actually didn’t fit correctly I should have yanked them off and returned them to Woodcraft, but hindsight is 20/20.
I guess I thought the polyurethane tires might be a onetime purchase but obviously I was mistaken, I don’t think it’s unreasonable to expect more than 3-4 years out of them though but maybe this is much more normal than the originals lasting for as long as they did.
So my question is what have y’all bought as replacement tires, does it actually fit correctly, how long have you had them, and knowing what you know now would you buy the same ones again ?
-- Regards, Charlie in Rowlett, TX --------I talk to myself, because sometimes I need expert advice.---------
10 replies so far
View Redoak49's profile
Redoak49
4356 posts in 2598 days
#1 posted 09-29-2018 01:22 PM
I have bought them from Bandsaw Tire Warehouse on eBay. I needed tires for an old bandsaw and nobody had the right ones. I called them and he got me perfect ones. I also bought ones for a 16” Jet and they were great.
You might want to check them out.
View Runner's profile
Runner
84 posts in 1383 days
#2 posted 09-29-2018 01:30 PM
I have urethane tires on my Powermatic 141. The fit is good, but the wheels are flat so I had to add a narrow strip of duct tape under the tires to create the crown. My urethane tires also have a poor seam that adds vibration. Not sure about the brand. Think I might go back to rubber tires next time.
-- Kjell - Eau Claire WI
View Gentile's profile
Gentile
357 posts in 2428 days
#3 posted 09-29-2018 02:39 PM
My old Delta kept throwing off blades. I couldn’t figure out what was going on until I ran it without the bottom cover.
The tire was spinning on the wheel. I bought some orange ones from the amazon. I had some difficulty putting them on, but I did it. They work great! They’ve been on for 2 years now…
-- "I cut it twice and it's still too short"
View splintergroup's profile
splintergroup
3219 posts in 1832 days
#4 posted 09-29-2018 02:46 PM
I’m in the same boat as Kjell (PM141). I used the Sulpher Grove Tool tires (orange) and I am totally sold on them.
If I recall correctly, the Jets have wheels slightly larger than the 14” specified diameter (14-1/4”?) so I’m surprised you have slipping. I’d try some 3M weather strip adhesive but I’d have to think about applying it before you install the tires (could get very messy) or using several screwdrivers to lift a portion of the installed tire and apply the adhesive into the gap, working your way around the wheel (the adhesive needs to set up a bit before joining, just like contact cement).
What ever replacement you get, check for width as they should extend lip to lip. You may be better off with just standard rubber replacements.
View Nubsnstubs's profile
Nubsnstubs
1663 posts in 2340 days
#5 posted 09-29-2018 03:14 PM
Back in ‘82-83, my tires just kinda fell off the saw one day. It would be about 2-4 weeks to get replacements if they could be found, and what I was doing at the time, my stuff was due in 2 weeks. Couldn’t wait that long, so asked a local Vulcanizing business if they could make up something for me. I had to remove the wheels, and took both to them. Two days later, I had my wheels back with rubber vulcanized in the groove where the tires would go. It’s been 36 years, and they are still as good as new. There has to be thousands of hours of use and abuse with no problems with my wheels. ............. Jerry (in Tucson)
View MrRon's profile
MrRon
5812 posts in 3853 days
#6 posted 09-29-2018 08:23 PM
I m in the same boat as Kjell (PM141). I used the Sulpher Grove Tool tires (orange) and I am totally sold on them.
- splintergroup
I used the same Sulphur Groove tires and the only problem I’ve had after 3 years is when sawing aluminum a tire broke because the chips would get embedded in the tire; not good! Should be OK as long as you cut only wood.
Charlie H.
#7 posted 09-29-2018 08:43 PM
Thanks to all for the feedback.
View BattleRidge's profile
BattleRidge
127 posts in 826 days
#8 posted 09-30-2018 03:12 AM
Are tires for your bandsaw available from Jet? Given that the original set lasted 8-9 years and that you weren’t satisfied with the aftermarket options, it might be good to go with something that worked in the past.
-- ~Art~
Charlie H.
#9 posted 09-30-2018 03:53 PM
Are tires for your bandsaw available from Jet? Given that the original set lasted 8-9 years and that you weren t satisfied with the aftermarket options, it might be good to go with something that worked in the past.
- BattleRidge
Yes the part number is available through Jet and several other sources.
They are all within a few dollars of being the same.
If I go that route I will probably buy fro eReplacement Parts since I have an account there and most of the things I have bought there are OEM packages.
The original tires were glued on, not messing with that along with thinking polyurethane was a superior replacement made the Carter tires seem like a no brainer.
The saw is still working fine right now, but I probably need to go ahead and replace the tires before they start flopping and cause a problem.
I mostly just wanted to know if my experience with the replacement tires is typical or if there’s something amiss on my end.
Charlie H.
#10 posted 10-04-2018 03:18 AM
I was at Woodcraft today and they had the Jet OEM tires in the store so I went ahead and got a pair.
The Carter tires came off very easily.
Of course I had to wrestle with the new ones a little bit but they went on without having to remove either wheel.
Hopefully the new tires will last a long time.
