Teak table?
Forum topic by katilicous posted 09-29-2018 09:08 AM 479 views 0 times favorited 3 replies Add to Favorites Watch
View katilicous's profile
katilicous
44 posts in 3014 days
09-29-2018 09:08 AM
Topic tags/keywords: teak wood identification patio furniture table chairs
Hi lumberjocks, thought to come here with a wood question. I’ve restored teak before and it hasnt quite felt like this wood…
I was given a table and chairs that are made to be an outdoor set in the style of teak furniture claimed by the owner to be teak.
The wood chairs say made in Indonesia on a sticker under the seat.
Here’s my issue accepting this as teak.
It’s very dry
Inconsistent color
Base of table and chair legs where they hit the ground are in bad shape, like rotting from water sitting on it.
The table was factory stained a reddish stain. I say factory because it was before the parts were installed.
L
-- If you fall, I'll be there. -Floor
3 replies so far
View crippledcarpenter's profile
crippledcarpenter
32 posts in 3056 days
#1 posted 09-29-2018 03:32 PM
it is most likely teak. I would guess from the live edge side of the cutting. teak none the less. it was stained to even out the tone to look more like heart wood. replace the bad parts, if you don’t have teak, white oak will work. give it a couple good coats of teak oil and it should do as well as it is going to.
-- haste makes firewood.
View jta's profile
jta
51 posts in 494 days
#2 posted 09-29-2018 05:00 PM
It looks like teak to me, but probably a lower grade or outer cut as suggested above. If it hasn’t been treated/well looked after or the factory stain did some damage to the wood (or the wood wasn’t heart teak) then it would make sense to have that problem. Easiest way to tell for sure is to sand back a little of the patina, which can be misleading particularly if its seen a lot of exposure.
For repair – don’t go with oak as suggested above (but I’m sure you know that) – its going to be nowhere near as endurant – you probably want to find another naturally resistant wood that you can blend in.
For restoring it, would suggest avoiding teak oil – its not actually for teak (linseed blend), causes unusual dryness, cracking and tends to be a negative impact on the teaks natural oils, and can lead to inconsistencies in the natural grey patina of UV exposed teak. It also requires regular application to maintain appearance. You can either go with a stripping agent to brighten the teak up, or go the sanding route (which I’ve taken for all my teak outdoor furniture as it was previously horribly stained). The recommended approach to achieve consistency is something like a Teak Sealant (e.g. Semco which costs an arm and a leg or similar) – its what they use on the luxury boat decks made out of teak, and can be used for teak to retain its new/fresh golden/red hue. It does require reapplication, but has less issues with cracking and requires less regular application (depending on climate).
I’ve done similar for the outdoor chairs, table, lounge, side tables and benches that I have to great results – will try and post a picture when I get a chance.
katilicous
#3 posted 09-29-2018 08:26 PM
Thanks for the replies. I have never heard not to use teak oil on teak. I ran out but had some linseed that is working out OK. I have sanded away the red stained areas that remain but can see why it was used on the blotchy parts.
Loved cleaning up my other teak set. Both I got for $20. A good deal no matter the wood. Seems sturdy. Thanks again
