Kreg foreman quality issues
Forum topic by CWWoodworking posted 09-28-2018 11:39 PM 1276 views 0 times favorited 11 replies Add to Favorites Watch
View CWWoodworking's profile
CWWoodworking
541 posts in 780 days
09-28-2018 11:39 PM
I love the machine, but I am on my 3rd one in 3 years. The first one had a design flaw, a cord was too short. Kreg replaced it no charge, which was cool. 2nd one just went dead.
I am hard on it. Probably use 15,000 screws this year.
Anyone use a heavier duty machine?
11 replies so far
View Jared_S's profile (online now)
Jared_S
273 posts in 561 days
#1 posted 09-29-2018 01:25 AM
Go with a castle machine.
View AHuxley's profile
AHuxley
874 posts in 3923 days
#2 posted 09-29-2018 01:47 AM
- Jared_S
100%. All pocket holes are not created equal and once you use a low angle pocket hole you will never go back. The 2 step process takes an extra couple of seconds a hole but that time is saved 10 fold on assembly time.
CWWoodworking
#3 posted 09-29-2018 01:57 AM
How hard is it to switch to thicker material? I use 3 different settings on a consistent basis.
I am sold on the low angle. I don’t use clamps in assembly so it sounds great if it works.
View waho6o9's profile
waho6o9
8811 posts in 3178 days
#4 posted 09-29-2018 02:06 AM
AHuxley
#5 posted 09-29-2018 02:31 AM
- CWWoodworking
Changing thickness is a non-issue most will be within the tolerance of the quick clamp’s range, if not you just need to adjust the quick clamp, that is assuming you just get the TSM-12, even less of an issue if you move up to the floor standing machines.
I know there is a big difference in price but as soon as you touch the TSM-12 you will realize it is built like a tank compared to a Foreman.
AHuxley
#6 posted 09-29-2018 02:35 AM
Looks like a winner:
https://www.youtube.com/watch?time_continue=2&v=dOYGHb8sduY
- waho6o9
That is the 100 I would NOT suggest it for 15,000 holes per year, at a minimum a TSM-12 for that level but that volume should support the capital investment of a TSM-22 in saved time.
waho6o9
#7 posted 09-29-2018 02:39 AM
Good to know thanks AHuxley.
View AlaskaGuy's profile
AlaskaGuy
5516 posts in 2911 days
#8 posted 09-29-2018 02:51 AM
- waho6o9
- AHuxley
It also weights 11 pounds. Seems like a guy might grow some mussels after 15000 screws.
AHuxley
#9 posted 09-29-2018 03:16 AM
- AlaskaGuy
Even the 100 is what I would consider overbuilt. I played with it at IWF while yacking with Feddie (the guy in the Castle video linked above AKA Got It Made on youtube). It is something for someone that makes a set or two of cabinets a year or is planning to make a single set and just wants to use low angle pockets. It is their way to compete with the $400 Kreg. But the TSM-12 is where the real production starts, but it simply can’t compete on price using 2 Bosch router motors and being made in the US but it is a different world in terms of build quality.
Jared_S
#10 posted 09-29-2018 04:41 AM
You could also look for a old porter cable production pocket cutter (re badged castle tsm-10) if you are shopping on the used market.
View dhazelton's profile
dhazelton
2839 posts in 2898 days
#11 posted 12-17-2018 08:08 PM
Yes, old post I know…..
I just bought a used one on CL and when the guy plugged it in the motor cut out when he pulled the handle. Of course he said it was the first time it did that, and maybe so…but yes – the wire that comes out of the handle and turns into the junction box should have a loop or something so it doesn’t kink and break. I e-mailed Kreg and they are sending me a new wire. I may do something different and put a paddle switch on the front though…
15,000 screws a year doesn’t seem like a quality issue as much as it it is overusing a prosumer/hobby tool.
