Outdoor Table Stain and Clearcoat
Forum topic by WoodMag posted 09-28-2018 02:56 PM 442 views 0 times favorited 5 replies Add to Favorites Watch
View WoodMag's profile
WoodMag
25 posts in 489 days
09-28-2018 02:56 PM
Topic tags/keywords: question pine finishing stain clearcoat uv table outdoor
I have a pine tabletop that I will be finishing sanding this weekend that I am staining or putting a clear coat on it. Is there a particular stain or coat that I should be looking for in regards to UV protection, eating surfaces, easy cleanup for outdoor table tops?
We’re not looking for a glossy surface. More of a satin or semi gloss but when looking for the stain there are plenty too choose from but want to make sure it appropriate for outdoor tables.
5 replies so far
View LesB's profile
LesB
2320 posts in 4054 days
#1 posted 09-28-2018 04:11 PM
I would use an exterior grade polyurethane or spar varnish for the top coat (actually 3 coats sanding lightly between them).
Almost any stain will work under the finish except that I have noted that Danish oil looses it’s color quickly when exposed to sun. Also you are working with Pine which is notoriously difficult to stain evenly so you need to put some sort of pre-stain finish on to control the absorption of the stain. One of two coats of de-waxed clear shellac diluted to a 1# cut (dilute with denatured alcohol) should do it. Zinssers makes one called Sealcoat. It is a 2# cut out of the can. It drys very quickly depending on ambient temperature ….I’m talking less than 30 seconds at 70 degrees and an hour to add a second coat. I find it easiest to wipe it on with a cloth (and latex gloves); sand lightly between coats with 320 sand paper.
If it is continuously exposed to a lot of sunlight and or other elements it will need to be refinished every couple of years. Protect it between uses with a cover if you can. If you let it deteriorate to long you will end up stripping it for refinishing so put a new top coat on every couple of years. I see you are in Calif. so sun is you enemy there.
-- Les B, Oregon
WoodMag
#2 posted 09-28-2018 05:15 PM
Thank you for the information.
It will not be in direct sunlight for 95% of the time. It’s going to be under a covered solid roof patio awning. However the late evening sun may beat down on it for about an hour.
View John Smith's profile
John Smith
2135 posts in 773 days
#3 posted 09-28-2018 06:09 PM
use the “search” feature as it is a topic that comes up regularly
with a hundred different answers. you just have to weed through them
and find what will work best for you in your climate.
avoid anything that says MINWAX on it – and you will be better off.
my favorite is Marine Spar Varnish for outside wood furniture items.
-- I am a painter. That's what I do. I paint things --
John Smith
#4 posted 09-28-2018 08:47 PM
View bilyo's profile
bilyo
962 posts in 1713 days
#5 posted 09-29-2018 01:41 AM
I have a wood bench on my deck that is protected from the sun most of the time. I think it was 4-5 years ago I finished it with an exterior stain like you would put on your house or fence. This particular brand (Olympic) also had a clear coating much like Tompson’s Waterseal. I put two coats of that over the stain. It has held up very well so far. The finish is not glossy, but would probably be suitable for a table. If and when re-finish becomes necessary, it should be easy to re-do.
