Drill bit index with multiples?
Forum topic by Ben posted 09-28-2018 12:42 AM 356 views 0 times favorited 3 replies Add to Favorites Watch
View Ben's profile
Ben
457 posts in 3465 days
09-28-2018 12:42 AM
I’m looking for a wood drill bit index/set with at least several of the same size bits.
For example, 5) 1/16”, 5) 1/8””, etc…
Every set I see only has one of each. As soon as that 1/8” bit falls off a ladder the functionality of the set drops about 90%. But it would be sweet to have a small case of a bunch. I suppose I can create that myself if I have to.
Thanks!
3 replies so far
View TheNJ's profile
TheNJ
10 posts in 1808 days
#1 posted 09-28-2018 01:33 AM
Woodcraft has one
wood river-100-piece-combo
View RobinDobbie's profile
RobinDobbie
147 posts in 2342 days
#2 posted 09-28-2018 02:00 AM
That woodcraft set goes on sale for half off several times a year(I think), which is much closer to its actual worth. These will not be the straightest bits you might buy.
edit: Oh yeah, looks like christmas might be the next cycle: https://camelcamelcamel.com/WoodRiver-100-Piece-Combo-Point-Twist/product/B00EC84YOO
View MrUnix's profile
MrUnix
7597 posts in 2806 days
#3 posted 09-28-2018 02:17 AM
Typically, it’s just the smaller bits that are prone to breakage – so buying something like that 100 pc kit from Woodcraft will include a lot of bits you will never use or need IMO. I find it easier and cheaper to just get multiple jobber packs of the sizes I use/break the most – which are basically just 1/16” and 1/8” in my case. You can get 7pc packs of HSS titanium coated 3/32”, 7/64” or 1/8” bits for less than $3, and a 7pc pack of 1/16” for under $2 at HF.
