Suggestions for floor protection
Forum topic by Blindhog posted 09-27-2018 11:19 PM 431 views 0 times favorited 8 replies Add to Favorites Watch
View Blindhog's profile
Blindhog
149 posts in 1658 days
09-27-2018 11:19 PM
Topic tags/keywords: question
I’m building a dining room table for my daughter out of 8/4 pecan. It will be apx. 84”x40” and will have some weight. The legs will be constructed out of 4×1 1/2 11 ga steel tube shaped into a rectangle. I’m trying to come up with a good way to protect the floors (they have hardwood flooring) and still be stable. I’m thinking about putting some nylon/HDPE on the bottom of the legs but not sure how to attach (adhesive/ drill and screw/etc.).
any ideas/experience/suggestions would be greatly appreciated.
Many Thanks,
Hog
-- Don't let perfection get in the way of plenty good enough
8 replies so far
View lumbering_on's profile
lumbering_on
578 posts in 1099 days
#1 posted 09-28-2018 01:25 AM
If you don’t want it to slide a lot, you can always use neoprene pads, which are similar to the material used on push pads.
https://www.amazon.ca/dp/B06XGTJHZ8/?coliid=I2NB6BLDCJH9W9&colid=24IUD0AAWO6F5&psc=0&ref_=lv_ov_lig_dp_it
lumbering_on
#2 posted 09-28-2018 01:25 AM
deleted double post
View CWWoodworking's profile
CWWoodworking
565 posts in 788 days
#3 posted 09-28-2018 01:48 AM
They make plastic push in things that will cover up the hole and provide a little protection. I would add felt to the plastic things.
CWWoodworking
#4 posted 09-28-2018 01:53 AM
Like this
View bold1's profile
bold1
330 posts in 2456 days
#5 posted 09-28-2018 02:09 AM
Cork. It will not slide on the hardwood. You can get it in sheets or blocks.
CWWoodworking
#6 posted 09-28-2018 02:31 AM
Does cork mar floor finishes over time? I honestly don’t know. My experience is things that are made with glue, rubber, plastic, etc leave marks eventually.
Your right about felt sliding, but with dining tables it is not as much of an issue.
View CaptainKlutz's profile
CaptainKlutz
2260 posts in 2103 days
#7 posted 09-28-2018 07:41 AM
IMHO – Problem with any heavy furniture on hardwood floor is dirt getting trapped under the feet and scratching up wood during inevitable movement. If it table is heavy, do not need to worry about limiting movement with cork or rubber.
I prefer to apply 1/4” wool felt, or indoor/outdoor carpet to bottom of furniture feet using contact cement. Soft pad will cushion dust/sand and reduce potential for floor damage.
Can also buy or make a custom rounded edge HDPE pad using wood working tools to attach on bottom surface with recessed screws. But I find that HDPE has low friction on hardwood, and table will slide a little too easy.
YMMV
Blindhog
#8 posted 09-28-2018 11:46 AM
Thanks to everyone for their ideas. Cork may be the solution as the table will be heavy enough to avoid any substantial movement.
