sheared brass screw
Forum topic by Pitt posted 09-26-2018 11:31 PM 589 views 0 times favorited 11 replies Add to Favorites Watch
View Pitt's profile
Pitt
38 posts in 4408 days
09-26-2018 11:31 PM
Hi all
Looking for advice. I was installing brass hinges on a jewelry box for my niece. I used stainless screws to “prep” for the brass screws, but sheared off the head on one anyway.
Any suggestions? It’s a #4 screw so smaller than any screw extractor I have.
Thanks for looking
PS – That’s not my wine glass in the background (yet)
11 replies so far
View Rich's profile
Rich
5126 posts in 1190 days
#1 posted 09-26-2018 11:45 PM
This is what I use.
https://www.woodcraft.com/products/screw-extractor-1-4
View Pitt's profile
Pitt
#2 posted 09-27-2018 12:18 AM
Thanks Rich
View shampeon's profile
shampeon
1900 posts in 2784 days
#3 posted 09-27-2018 12:29 AM
Go get some brass tubing in a hobby or hardware store. Make sure it’s just slightly larger than the diameter of the screw threads. Cut a couple teeth into the end with a file. Chuck it into a drill and drill out the screw, slowly.
View Aj2's profile
Aj2
2645 posts in 2399 days
#4 posted 09-27-2018 01:28 AM
When that happens to me I drill a hole right next to the broken screw. Then push it over into the hole. Then the fix is to drill a hole with a drill press just bigger then both. Its usually 3/16 for me.I also make the plug with a dowel plate.
-- Aj
View Lazyman's profile
Lazyman
4469 posts in 1988 days
#5 posted 09-27-2018 03:28 AM
If the top of the broken screw isn’t too deep, I have had luck using a small 6 in. Long Nose Locking Pliers from Harbor freight to grab the top and unscrew it . You may have to chip out a little wood to get a good grip.
Correction: I think that it is actually the long nose plier from this HF mini locking plier set.
View CaptainKlutz's profile
CaptainKlutz
2203 posts in 2095 days
#6 posted 09-27-2018 10:12 AM
+1 Rich’s screw extractor solution from Woodcraft. Especially for broken screw in side of board like one shown.
Hate using solid brass screws in hardwood. I replace all brass screws that come with small hardware with brass plated steel screws. You can still break heads off if you try hard, but they have a much more predictable break point .vs. fragile solid brass screws.
Best Luck.
View Redoak49's profile (online now)
Redoak49
4341 posts in 2589 days
#7 posted 09-27-2018 11:06 AM
I have used the Woodcraft screw extractor a few times.
View Peteybadboy's profile
Peteybadboy
1462 posts in 2550 days
#8 posted 09-27-2018 11:25 AM
This is a really good topic. I think it will happen to all of us at one point or another. I think I will buy the screw extractors. Thanks for posting and all the replies.
-- Petey
View Pitt's profile
Pitt
#9 posted 09-27-2018 12:04 PM
Thanks everyone – as usual, very helpful advice
Pitt
View Rich's profile
Rich
#10 posted 09-27-2018 02:02 PM
I always use a lubricant as well. Through the years I’ve used a soap bar, beeswax and others, but lately I found a product called Screw Wax that comes in a tin and works well. What I like about it versus other commercial products I’ve tried is that it doesn’t stain the wood. FastCap makes a similar product that does a good job of lubricating the threads, but soaks in and darkens the wood.
You can find the Screw Wax product lots of places.
https://www.woodworkingshop.com/product/sc98957/
View theart's profile
theart
153 posts in 1155 days
#11 posted 09-27-2018 03:15 PM
My first go would be cutting a slot in the top with a Dremel and thin cutoff wheel. Then backing it out with a screw driver. Shampeon’s tube approach if that doesn’t work. I try to avoid extractors that small, because I usually end up snapping them.
