How to Hang a HAND RAIL
Forum topic by dakremer posted 09-26-2018 06:49 PM 711 views 0 times favorited 25 replies Add to Favorites Watch
View dakremer's profile
dakremer
2746 posts in 3692 days
09-26-2018 06:49 PM
Topic tags/keywords: handrail
The picture above is my set up with stud spacing drawn in.
I’m trying to install a handrail on these steps. Just a basic pine hand rail (with metal brackets) similar to this….
I’ve never done this before, so looking for advice on bracket spacing/anchoring….
For a hand rail this length, what is the appropriate number of brackets? 2-4?
It seems like if I place the brackets on the two inner studs (2 & 3), there will be too much overhang on the ends and it won’t be sturdy enough.
If I place a bracket on the two outer studs (1 & 4) it seems those brackets will be too close to the end of the handrail making it hard to finish the rail (45 degree miter joint to the wall). Also, a 3rd bracket in the middle will be oddly spaced if attached to a stud, so would need to be attached using drywall anchors (not in stud).
Aesthetically, 3 brackets spaced evenly would look best, but that means they’d all miss studs, and would be attached using drywall anchors.
If I use the end studs as to place brackets, I won’t have room to finish the ends of the hand rail, terminating them at the wall (using a miter joint). Maybe I should just skip turning them into the wall?
How would you go about doing this? What’s the “proper” way? Are drywall anchors strong enough? Should I be using two brackets or three brackets? How should they be spaced?
I hope this all makes sense. Lol
#Perplexed
-- Hey you dang woodchucks, quit chucking my wood!!!!
25 replies so far
dakremer
#1 posted 09-26-2018 07:08 PM
I should also note, I believe this is a plaster wall, not drywall…
View WoodenDreams's profile
WoodenDreams
878 posts in 512 days
#2 posted 09-26-2018 07:12 PM
I’ve installed hand rails twice before. Each time I put a the brackets on each stud. Going by your picture, I’d put in 4 brackets. The rails will have more strength with the brackets near the end, and each stud in between. normally 16” apart, and on the studs. If you need to turn them in, do it just after the bracket on the uppersection. The lower turn in, could you wrap the turn in around the corner? per the 1st picture. USE THE STUDS FOR YOUR ANCHORS. If not, run a 3/4” thick board on the wall the length behind the brackets. Anchor the board to all the studs then install 4 brackets to the runner board. The board will act as a accent trim behind the rail.
dakremer
#3 posted 09-26-2018 07:17 PM
the problem is that stud 1 and 4 are right next to the vertical trim so the bracket will be right up against the trim – which won’t look great but also won’t give me enough room to turn/miter the handrail into the wall….
WoodenDreams
#4 posted 09-26-2018 07:35 PM
Ok, What about installing a 1”x6” runner board the length 1st. Than you can the 4 brackets where you wish between your end turn-ins.
View Kazooman's profile
Kazooman
1408 posts in 2553 days
#5 posted 09-26-2018 07:38 PM
Unfortunately, the time to plan for the handrail was before the drywall went up. Appropriate blocking installed between the studs would have provided a solid anchor point at a reasonable distance from the end of the rail. It looks like the best method might be to have the rail long enough so that it overlaps the trim with or without turning back into the wall.
I recently had a bathroom remodeled. Decided against installing a handicap grab rail in the shower at this point in time since we do not need it. However, I had them install 2 X 10” blocking between the studs at positions where a future rail would go. All documented with drawings and photos before the expensive shower enclosure was installed. A wide variety of rails (length, angle on the wall, etc.) can be added in the future with firm anchoring into the blocks.
A “no holds barred, money is no object, super high quality” fix for your dilemma would be to pull off the drywall, install the blocking, re-drywall, and hang the rail.
dakremer
#6 posted 09-26-2018 07:43 PM
- Kazooman
Yeah, I wish everyone would do things “right” the first time. This house is 100 years old, so not sure a handrail was even a consideration when this was built. The steps can be a little slick, so I definitely need a handrail with a pregnant wife roaming around!
Definitely not taking the plaster down to install a handrail :) :)
dakremer
#7 posted 09-26-2018 07:44 PM
Since this is a lath/plaster wall, would some wall anchors be strong enough since it would be anchored behind the lath? I’m assuming not
dakremer
#8 posted 09-26-2018 07:48 PM
I ve installed hand rails twice before. Each time I put a the brackets on each stud. Going by your picture, I d put in 4 brackets. The rails will have more strength with the brackets near the end, and each stud in between. normally 16” apart, and on the studs. If you need to turn them in, do it just after the bracket on the uppersection. The lower turn in, could you wrap the turn in around the corner? per the 1st picture. USE THE STUDS FOR YOUR ANCHORS. If not, run a 3/4” thick board on the wall the length behind the brackets. Anchor the board to all the studs then install 4 brackets to the runner board. The board will act as a accent trim behind the rail.
- WoodenDreams
I want to keep the railing contained within the vertical trim, and not wrap around the bottom or top. I also don’t think I’ll like the look of the trim board behind that railing. I guess I could really upgrade the stairwell and add a wainscoting, and then put the trim on that. Seems like a lot of extra work though :)
View JADobson's profile
JADobson
1448 posts in 2712 days
#9 posted 09-26-2018 07:54 PM
- WoodenDreams
This seems like the best option.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
dakremer
#10 posted 09-26-2018 08:26 PM
maybe the best option for sturdiness, but not for aesthetics.
WoodenDreams
#11 posted 09-26-2018 08:26 PM
All on your personal preference for strength and looks.
dakremer
#12 posted 09-26-2018 08:48 PM
- WoodenDreams
Yep, I absolutely agree. The board behind the railing would not be my preference for looks, so looking for different options
View OnhillWW's profile
OnhillWW
206 posts in 1833 days
#13 posted 09-26-2018 08:50 PM
If it were my project I would:
A) Check to see if the wall on the other side of the stairs provides better options – different stud spacing etc.
B) As long as the handrail is a strong unit, I would go with using the two center studs as a place to anchor the 2 brackets. Then install the handrail – then with the use of in-wall anchors (many options out there) place and install a bracket near each end. I would be careful about drilling around that switch as obviously there is wiring in the wall there. Two brackets in a stud will carry the lion’s share of the load, with a stiff handrail any load will be shared so I think your going to be OK.
-- Cheap is expensive! - my Dad
dakremer
#14 posted 09-26-2018 08:52 PM
B) As long as the handrail is a strong unit, I would go with using the two center studs as a place to anchor the 2 brackets. Then install the handrail – then with the use of in-wall anchors (many options out there) place and install a bracket near each end. I would be careful about drilling around that switch as obviously there is wiring in the wall there. Two brackets in a stud will carry the lion s share of the load, with a stiff handrail any load will be shared so I think your going to be OK.
- OnhillWW
That’s kind of what I’m learning towards – use the two studs in the middle and then wall anchors on two other brackets at the ends. I just wasn’t sure if this was a big no-no (using anchors) or not. I would imagine anchors into lath is decently strong.
JADobson
#15 posted 09-26-2018 08:59 PM
- dakremer
I don’t know. If you paint the board to match and do a neat job of butting it up against the existing trim I think it would look pretty good. If you wanted to get fancy you could do some wainscotting below. Make it look like you planned it that way.
