Which Sanding Method for Table Top
Forum topic by WoodMag posted 09-26-2018 04:54 PM 541 views 0 times favorited 15 replies Add to Favorites Watch
View WoodMag's profile
WoodMag
25 posts in 482 days
09-26-2018 04:54 PM
Topic tags/keywords: table top sander swirl pine walnut question sanding rustic
I have a Sugar Pine Wood table top that I using to build my table. The planing mill removed the 3/16 crown now it’s up to me to sand it down to the finishing top. When complete it will be stained slightly darker (light walnut) so the grain will be seen.
I’m not sure if I want to use a belt, orbital, random orbital or by hand to sand the table top. Obviously I don’t want swirl marks so I’m concerned with the orbital or random. I’m concerned with the belt sander as “too aggressive” as I’m not trying to remove anything… just trying to finish it.
Anyone have any recommendations?
15 replies so far
View John Smith's profile
John Smith
2131 posts in 766 days
#1 posted 09-26-2018 05:01 PM
really nice piece of wood !!
how old is it ? how has it been stored ? has it been properly dried before you got it ?
my avenue of approach would be using the “less aggressive” methods first.
then, slowing moving up the ladder as required to obtain the finish you want.
then down to the bottom of the list with card or cabinet scrapers, 320 grit paper, etc.
oh – there is no truth to the rumor that “elbow grease” will stain raw wood !!!! (as in hand finishing).
-- I am a painter. That's what I do. I paint things --
View LittleShaver's profile
LittleShaver
609 posts in 1223 days
#2 posted 09-26-2018 05:24 PM
I’m partial to a card or cabinet scraper. Not a fan of tailed dust and noise makers, unless there is some serious stock removal to be done that can’t be done with a plane or other quiet tool.
-- Sawdust Maker
View Rich's profile
Rich
5134 posts in 1193 days
#3 posted 09-26-2018 05:33 PM
Don’t skip grits, particularly in the coarser starting grits. Get to 180 to 220 and then finish by hand sanding with the grain. The grain will hide such fine scratch marks and, as long as you sanded thoroughly at each grit leading up to it, there won’t be any random scratch marks.
Also, dye will not highlight scratches you may have left behind as much as stain will. Stain solids settle down in the scratches and they really show.
View pottz's profile
pottz
7662 posts in 1588 days
#4 posted 09-26-2018 05:34 PM
well if its really rough id start with my wide belt sander then id go to the ros and work down the grits,which i have no problem having swirl marks at all.the thought of smoothing a slab that big with a scraper just makes my arms sore,plus ive got better things to do.nice slab.
View Madmark2's profile
Madmark2
690 posts in 1191 days
#5 posted 09-26-2018 06:14 PM
Sanding opens the pores in the wood and will then take more stain and look darker. Using a scraper will not open the pores like a sander will and will absorb less stain.
Do not use a belt sander.
M
WoodMag
#6 posted 09-26-2018 06:37 PM
I’m not sure of the exact age of the piece but the planing mill said it has almost no sap (or they wouldn’t have taken the job) and it was “pretty dry”. The environment that I’m in has been 90-100 degrees for 5 months with no rain or moisture. Any piece (unless recently cut) is going to be pretty dry.
Would a orbital sander starting at 180 and moving through the grits to 320 be the best course? Perhaps finishing with a hand sand of 400?
pottz
#7 posted 09-26-2018 06:44 PM
I m not sure of the exact age of the piece but the planing mill said it has almost no sap (or they wouldn t have taken the job) and it was “pretty dry”. The environment that I m in has been 90-100 degrees for 5 months with no rain or moisture. Any piece (unless recently cut) is going to be pretty dry.
- WoodMag
if the mill gave you a pretty smooth surface i would start at about 120 and go through the grits and finish at 400,you’ll end up with a nice finish,or wear your hands and arms out scraping-lol. ive been wood working for 50 years and this always works well for me,check my work if you want.
WoodMag
#8 posted 09-26-2018 07:11 PM
if the mill gave you a pretty smooth surface i would start at about 120 and go through the grits and finish at 400,you ll end up with a nice finish,or wear your hands and arms out scraping-lol. ive been wood working for 50 years and this always works well for me,check my work if you want.
- pottz
Then use a Orbital starting at 120 ending with 320? Want to make sure that moving through grits will eliminate swirl marks. It’s pretty smooth with the exception of a few small corner areas where I’ll need some 60 grit and a belt sander to get it workable.
pottz
#9 posted 09-26-2018 07:21 PM
if the mill gave you a pretty smooth surface i would start at about 120 and go through the grits and finish at 400,you ll end up with a nice finish,or wear your hands and arms out scraping-lol. ive been wood working for 50 years and this always works well for me,check my work if you want.lumber jocks.
Then use a Orbital starting at 120 ending with 320? Want to make sure that moving through grits will eliminate swirl marks. It s pretty smooth with the exception of a few small corner areas where I ll need some 60 grit and a belt sander to get it workable.
- WoodMag
sounds good enjoy the process,thats gonna make a beautiful table,cant wait to see it finished.also welcome to lumber jocks.
WoodMag
#10 posted 09-26-2018 07:33 PM
Thanks. I’m looking forward to it as well. This is my first table and working with this large/type of wood (done other projects) so I’m going to take it slow and make sure it’s done right.
View Rich's profile
Rich
#11 posted 09-26-2018 08:09 PM
- Madmark2
I’d be interested to see your source for this.
View WoodenDreams's profile
WoodenDreams
882 posts in 514 days
#12 posted 09-26-2018 08:16 PM
Use a belt sander with the grain, orbit, by hand is all personal preference. Wanting a super nice finish may be in your #grit sand paper you finalize in. Or are you finishing it off in epoxy.
WoodMag
#13 posted 09-26-2018 08:47 PM
I’m eventually going to go from 120 up to 400 grit on a random orbital hand sander.
I’ll take pictures and post as I go.
View Kirk650's profile
Kirk650
679 posts in 1352 days
#14 posted 09-26-2018 09:51 PM
Do not use a belt sander. Almost impossible to control the amount of wood removed. Start with a ROS to 320 and hand sand with the grain with 400 grit.
pottz
#15 posted 09-26-2018 10:05 PM
I m eventually going to go from 120 up to 400 grit on a random orbital hand sander.
I ll take pictures and post as I go.
- WoodMag
you’ll be fine,this aint rocket science,just sanding wood until its smooth,no need to over think it.
