Looking for cheapest 1-1/4" standoff, brushed metal
Forum topic by jamsomito posted 09-26-2018 01:21 AM 954 views 0 times favorited 8 replies Add to Favorites Watch
View jamsomito's profile
jamsomito
457 posts in 1036 days
09-26-2018 01:21 AM
I need 20 short rods or standoffs to hold some decorative pieces off of a wall-hung surface, making a floating illusion. I figured I’d get a brushed aluminum rod and cut 1-1/4” off , then drill a matching hole in the backer surface and the “floating” pieces and epoxy them in. Maybe I’m missing it but I can only find drive shafts on McMaster Carr, and I don’t need carbon steel, and the actual standoffs they have are fairly pricey at more than a buck a piece, not to mention look like work mechanically differently.
Anyone have any ideas?
8 replies so far
MrUnix
7599 posts in 2809 days
#1 posted 09-26-2018 01:30 AM
Got a lathe? Pretty trivial to make them on one if you do.
View 000's profile
000
2859 posts in 1509 days
#2 posted 09-26-2018 01:31 AM
I’ve always bought them from CRL
Just looked at the price, 1/2” x 1 1/4” 4.29 each (not cheap)
View lumbering_on's profile
lumbering_on
578 posts in 1100 days
#3 posted 09-26-2018 01:32 AM
If you’re just looking at the aluminum rod, I believe that Home Depot carries it. However, I thought that standoffs were two parts – i.e. a threaded rod and a hollowed out rod? Is that what you’re looking for?
jamsomito
#4 posted 09-26-2018 02:34 AM
- MrUnix
Sadly, no. :(
If you re just looking at the aluminum rod, I believe that Home Depot carries it. However, I thought that standoffs were two parts – i.e. a threaded rod and a hollowed out rod? Is that what you re looking for?
- lumbering_on
I’ll have to check there. No, I don’t need a standoff in the traditional sense, just some way to make some smaller pieces float off a backer board. I like the look of brushed metal since it matches the rest of the hardware in the room, but I suppose it doesn’t even have to be that if it was small enough to be hidden. Kind of like that aesthetic though.
MrUnix
#5 posted 09-26-2018 02:47 AM
Sounds like your original idea would work, and are just looking for some solid rod? You can get aluminum rods at Grangers, McMaster Carr, MSC, Fastenal, the BORG, tractor supply, most hardware stores, etc… (eg: 1/4” x 36” solid rod for ~$4.21 at Home Depot – which would get you more than 20 pieces). Chuck ‘em in a drill and you can give them a brushed look easily with some fine sandpaper.
jamsomito
#6 posted 09-26-2018 03:45 AM
Sounds like your original idea would work, and are just looking for some solid rod? You can get aluminum rods at Grangers, McMaster Carr, MSC, Fastenal, the BORG, tractor supply, most hardware stores, etc… (eg: 1/4” x 36” solid rod for ~$4.21 at Home Depot – which would get you more than 20 pieces). Chuck em in a drill and you can give them a brushed look easily with some fine sandpaper.
- MrUnix
Ok thanks for that. I must have missed it on McMaster when I looked. I’ll check again and also at my local place
View TheFridge's profile
TheFridge
10859 posts in 2096 days
#7 posted 09-26-2018 04:29 AM
1/2” (7/8 od) rigid aluminum conduit? Wire wheel on a bench grinder?
View John Smith's profile
John Smith
2135 posts in 772 days
#8 posted 09-26-2018 06:27 PM
you would be surprised at just how easy it is to take a piece of aluminum tubing
and hold a piece of 220 grit sandpaper in your hand and massage it up and down.
it will produce a very nice subtle brushed finish worthy of any display.
or ~ if you wanted the brush marks to go around the tubing instead of lengthwise,
chuck it into your drill and hold something abrasive in your hand – steel wool, sandpaper, etc.
also 1/2” copper pipe, for that matter. but copper must be clear coated to prevent oxidation.
then cut to length on your band saw or miter saw.
-- I am a painter. That's what I do. I paint things --
