New Rabbet Plane (MillersFalls #85 - maybe?)
« back to Hand Tools forum
Forum topic by BobinSachse posted 09-25-2018 05:58 PM 914 views 0 times favorited 8 replies Add to Favorites Watch
View BobinSachse's profile
BobinSachse
48 posts in 2051 days
09-25-2018 05:58 PM
I just purchased an old Rabbet Plane that is similar to a Stanley #78. I only has none marking on it. Just ahead of the handle on the left side, it says “Made in USA”
On the direct opposite side the body is checkered with a non checkered “Oval” portion within. On some Millers Falls # 85 planes, it is stamped in that non checkered oval with “Millers Falls #85”. This one has nothing.
Any ideas on this one?
-- Bob Y.
8 replies so far
View Bill White's profile
Bill White
5241 posts in 4561 days
#1 posted 09-25-2018 06:07 PM
Any markings on the iron? Could be that yours is one made for another company/seller.
Clean it up and use it. They work well if set up properly.
-- [email protected]
BobinSachse
#2 posted 09-25-2018 06:58 PM
- Bill White
I plan on it. The rod the fence rides on is bent, but that can be straightened. Everything is there so I’m not missing any parts.
I got it, a Stanley #51 Spoke shave and a Bailey #3 for $80
the Bailey has a broken Frog and a missing lever cap, so whoever had it put a small block of wood on top of the chip breaker and uses the existing screw t hold it in place. It actually works.
-- Bob Y.
View Don W's profile
Don W
19419 posts in 3168 days
#3 posted 09-26-2018 08:56 AM
Nothing on the iron? It was probably made for a house brand such as Craftsman or Wards.
View olegrump's profile
olegrump
97 posts in 823 days
#4 posted 09-28-2018 12:49 PM
I agree that it was probably sold through either Sears or Ward’s. They sold a lot of stuff by Miller’s Falls as their own brands. These usually are really good planes in use.
View bandit571's profile
bandit571
24343 posts in 3284 days
#5 posted 09-28-2018 01:18 PM
My #78 is a Stanley made plane…iron is stamped as a WARDS MASTER QUALITY…
Pattern on the handle of the OP’s LOOKS like a Millers Falls style. Depth stop bolt MAY have been a replacement, mine has a shouldered thumbscrew. Same thing with the fence bolt. Mine there is also a thumbscrew. .Depth adjust lever is either been bent, or is a non-Stanley pattern.
Millers Falls tended to do almost a direct copy of Stanley planes….
Pattern along the top of the OP’s plane is different than a Stanley made version, as well.
bandit571
#6 posted 09-28-2018 07:15 PM
Photos of mine, to compare with the OP’s plane…
Note the end of the depth adjuster lever. Iron has Wards Master Quality
Close?
Hmmm.. was told a long time ago, if the handle has a dimpled texture, it was by Stanley
May want to look up what handle Millers Falls used?
Don W
#7 posted 09-28-2018 09:13 PM
if it’s a Millers Falls the fence rood will be a standard thread size.
BobinSachse
#8 posted 09-29-2018 02:52 PM
Close, but not quite the same one…. The texturing of the handle appears to be a little different.
Thanks for everyone’s input.
I’m gonna clean it up and either straighten the fence rod, or get another one that is straight.
It will be a good plane!!
Photos of mine, to compare with the OP s plane…
Close?
- bandit571
-- Bob Y.
