Forum topic by bgilb | posted 09-15-2018 11:11 PM | 1208 views | 0 times favorited | 4 replies | ![]() |
Anyone else have this saw? I thought the fence was supposed to be upgraded. Overall the fence feels like garbage. It doesn’t slide easily. The “Teflon” has been scratching the aluminum front rail. Getting it perfectly aligned is also a nightmare. You either end up bottoming out the set screws or the set screws are higher than the table. |
#1 posted 09-16-2018 02:11 PM |
Hi bgilb, It’s a common problem with the long set screws. They sent out shorter ones after they were informed of the issues. I’m surprised they have not corrected this in production. The fence has been pretty good…so good that I have not installed the Vega yet. -- “Facts don't care about your feelings.” ..., Ben Shapiro |
#2 posted 09-16-2018 06:14 PM |
Does it move very smoothly? Like you can barely slide it and it will coast? |
#3 posted 09-16-2018 07:21 PM |
Yes, It is smooth. If it is too tight, adjust the teflon pads that pushes against the front rails. I had to play with it to get it the way I wanted but so far it has been a solid fence. -- “Facts don't care about your feelings.” ..., Ben Shapiro |
#4 posted 09-17-2018 01:31 PM |
I have this saw and find that if you try to keep some slight pressure against the front rail and hold it flat against it, it will slide smoothly, but otherwise can get stuck when trying to slide. I also had the problem with it scratching the top of the rail, but it hasn’t gotten any worse and I don’t really worry about it anymore. If you are having trouble with the set screws, when trying to square it to the table or dial in the height, you can also adjust the height of the fence faces slightly. If you flip the fence upside down, you can access the bolts that hold the faces on. If you loosen them, there is a small amount of adjustability to the faces. One of the faces on mine is slightly concave and the other is flat. Since, I don’t really use the right side, I ended up swapping them around. After doing this, I had issues with the set screws either sticking up above the table or bottoming out, until I realized that I must have changed height of them and had to readjust. If you are still having trouble, you can give this a try and see if that helps. It’s a bit of a pain, since the fence has to be upside down. Also, I found that I had to remove the indicator/cursor on the left side, as it was causing the screw heads that hold it on to be too high and interfering with stock during rip cuts. I don’t really use the fence on the left side of the blade, so this didn’t matter. Once I was able to get everything dialed in, I haven’t had to re-adjust anything yet and have been happy with it. |
Forum | Topics |
Woodworking Skill Share
13136 |
Woodturning
2783 |
Woodcarving
564 |
Scrollsawing
413 |
Joinery
1869 |
Finishing
6302 |
7855 |
32533 |
CNC Woodworking
325 |
Hand Tools
6421 |
Jigs & Fixtures
1784 |
Wood & Lumber
7243 |
1613 |
Focus on the Workspace
2614 |
1266 |
Woodworking Trade & Swap
5393 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9626 |
