Woodmaster 718 planer vs Powermatic 100 12" planer
Forum topic by Poplarguy posted 09-15-2018 01:59 AM 941 views 0 times favorited 2 replies Add to Favorites Watch
View Poplarguy's profile
Poplarguy
42 posts in 502 days
09-15-2018 01:59 AM
I currently have a Woodmaster 718 and am pleased with it. I use it only for planing at this point.
I have an opportunity to purchase a well maintained 60’s era Powermatic 100 12” planer for under $300.
How much, if any, difference will there be in the finished product in the Woodmaster vs the Powermatic, all things being equal (sharp blades, properly set up machine, etc).
2 replies so far
View AHuxley's profile
AHuxley
874 posts in 3934 days
#1 posted 09-15-2018 02:12 AM
Moulder/planers have a rather long distance between the head and the rollers (required for moulding knife clearance) as well as not having chipbreakers or pressure bars this all equals a higher propensity for chatter.
The bottom line is the PM 100 is a better planer, whether or not the quality is worth giving up 6” for YOU. The one thing I would say is BUY it, you should have already. About the worst case is you use it, it doesn’t work out for you and you sell it for MORE than you paid.
Poplarguy
#2 posted 09-27-2018 01:19 AM
Well I wound up picking the little machine up as I’m a sucker for old iron. After running some oak and poplar boards through both machines, it seems there really isn’t much difference. There is snipe with the PM, but that might be attributed to the feed/exit table being much shorter than it is on the WM and/or because of the poly bed might be a help on the WM as well.
Regardless, I’m pleased with the purchase, if even for the nostalgic reasons.
