Attach sprocket to threaded rod for Drum Sander build
Forum topic by RyanBWood posted 09-12-2018 02:11 PM 1700 views 0 times favorited 8 replies Add to Favorites Watch
View RyanBWood's profile
RyanBWood
8 posts in 502 days
09-12-2018 02:11 PM
Topic tags/keywords: question
Hey everyone,
I am working on my design and build plans for a thickness sander / aka drum sander. I am doing a combination of Stumpy’s 2 in 1 with top access, as well as 4 post height adjustment from Johnzo, Tom, GeorgeM, . http://lumberjocks.com/projects/37885 , http://lumberjocks.com/projects/43625
I am collecting parts in the next few weeks and I am stuck on the sprocket type and mounting them to a threaded rod.
Being in Canada, I have less of the cool hardware stores to pick from. I have Princess Auto… which if you don’t know if bottom of the barrel stuff in a lot of cases. They carry pulleys I plan to use, which are basic keyed v belt, totally workable.
The sprockets and chain are very limited and ONLY carry the weld on sprockets that mount on hubs.
Another local commercial supplier here carries higher grade stuff, but a basic sprocket x 4 + chain will run me $80 alone… at #35 chain. but still have a mounting issue with them. they were 3/4 fixed bore, set screw, no key versions.
How do you secure them to a threaded rod ? I figured this would be an easy answer on the google… not so much.
My initial thought is either one of the fixed bore types, with JB weld, lock nuts on top and bottom of the sprocket. ( or lock washer and regular nut job )
Fixed bore, no key, set screw type
fixed bore with key and set screw
hub and weld on sprocket
Which would you use, or have used in this situation ?
  • Second question , sorta
the shaft for the drum. I was planning on using a keyed 3/4 shaft. with has a key way on the entire length… i can then cut ot size, but easy to mount whatever pulley i deside on. Any concerns you see on a full length keyway, or should I also use a 3/4 threaded rod for the drum shaft just like the above plan.
-- Full time kid chauffeur, woodworking on the side.
8 replies so far
View lumbering_on's profile
lumbering_on
578 posts in 1098 days
#1 posted 09-12-2018 03:03 PM
Being from Ottawa, I feel your pain.
Have you checked out Mattias Wandel’s site? There’s a collection of sanders there.
https://www.woodgears.ca/sander/index.html
Best of luck.
RyanBWood
8 posts in 502 days
#2 posted 09-12-2018 03:38 PM
yah, lots of great ideas there too. but not detailed enough on what I was looking for.
I have never used pulleys or sprockets, so no experience in the mounting to the drive rods or bearings. bit of a learning curve on this one for me.
View TheFridge's profile
TheFridge
10859 posts in 2094 days
#3 posted 09-12-2018 04:53 PM
I’ve used sprockets on threaded rod. It sucked.
RyanBWood
8 posts in 502 days
#4 posted 09-13-2018 02:19 PM
ok, but how did you use them and what do you think would make them work ? I would need it to work somehow.
what sucked about it ?
View MrRon's profile
MrRon
5812 posts in 3852 days
#5 posted 09-13-2018 04:12 PM
This place will have everything you need for your project at very low prices. https://www.surpluscenter.com/ They ship to Canada, but I don’t know the cost involved.
View HokieKen's profile
HokieKen
12008 posts in 1747 days
#6 posted 09-13-2018 06:26 PM
If I were mounting the sprockets on threaded rod, I think I’d grind flats for the set screws to seat on and use a file to make sure the flats were parallel to one another and the set screws. Another thought would be to fill the threads with JB Weld or similar and slide the sprocket over it a time or two while it’s wet to size it. Then you basically have a threaded rod with a solid end. Finally, If you can get a sprocket that has a bore diameter close to the minor diameter of your thread, you may be able to tap threads into the sprocket to fit on the rod. That’s highly dependent on how hard the sprocket is though.
-- Kenny, SW VA, Go Hokies!!!
RyanBWood
8 posts in 502 days
#7 posted 09-13-2018 07:25 PM
I will probably go with surpluscenter for sure. prices are better.
i am leaning to do this:
Fixed bore sprocket with our without a key won’t matter
flattened spot for set screw
threaded filled with job weld and sprocket set in place
Lock nut on top and bottom.
Next, how to cap each end of the rod into a bushing / bearing to keep it from wobble and also allow easy rotation.
View DrDirt's profile
DrDirt
4600 posts in 4351 days
#8 posted 09-13-2018 07:31 PM
WHy sprockets? Most sanders went with belts and pulleys rather than a chain.
ANyway – For the threaded rod, you can take a grinder/Dremel and make a flat spot for a set screw
I personally would go pulleys, but even they need to be secured, so I would use the keyed shaft instead of a piece of allthread.
