Large, mobile table saw workstation
Forum topic by emilime75 posted 09-09-2018 04:37 PM 1180 views 0 times favorited 13 replies Add to Favorites Watch
View emilime75's profile
emilime75
6 posts in 1298 days
09-09-2018 04:37 PM
Curious why every one of these I see places the casters at the far corners, as opposed to further in, towards the center?
I’m planning a build for my home shop. It’ll house a Unisaw and a Delta contractor saw dedicated to dadoes, along with a router insert. Rough dimensions are looking like 84 by 36, and it’s going to be heavy. The obvious challenge is making a base that won’t sag with that much weight and at that span, while keeping a decent amount of space available for storage.
My thought is to bring the casters inwards, and closer to center, where the majority of the weight will be. The storage and router provisions will cantilever out from there. This would eleiminate about 40-44” of free floating span and place the weight of the 2 saws more directly on top of the casters.
I don’t want to add casters in the center for fear of additional twisting/racking on an uneven floor.
Thoughts?
13 replies so far
View Walker's profile
Walker
194 posts in 1080 days
#1 posted 09-09-2018 05:32 PM
I would think casters on the corners would keep it from tipping with a heavy load placed on the end.
If you don’t want to do 6 or 8 casters…how about the 4 casters towards the center as you said, then some adjustable feet on the corners. That would help you level it on the uneven floor, then retract/remove them for moving. If you’re able to lift the corners just a little, it could be as simple as a block of wood.
-- ~Walker
Rick Dennington
6789 posts in 3803 days
#2 posted 09-09-2018 08:03 PM
Go to my Blog, and look up “A new look for an old workhorse”, and you can see how I built the saw cabinet when I re-furbished my old Craftsman table saw….Look at how I built the platform for the base to sit on….Braced up underneath and casters on each end…I later put 2 more casters in the middle, and levelers front and back….This will give you some idea of how to build a support platform, and then go from there….
-- " There's a better way.....find it"...... Thomas Edison.
View AlaskaGuy's profile
AlaskaGuy
5522 posts in 2917 days
#3 posted 09-10-2018 12:41 AM
Rick, you know you can add a link to you post a take people right to your blog.
http://lumberjocks.com/Dustmite/blog/15531
Rick Dennington
#4 posted 09-10-2018 02:58 AM
Thanks, AG…...I had forgotten I could do that…Just didn’t think about it at the time….’ppreciate it…!!
View Steve's profile
Steve
1702 posts in 1191 days
#5 posted 09-10-2018 12:57 PM
i put my casters at the corners so i could get to them to lock them in place.
View Tony1212's profile
Tony1212
375 posts in 2343 days
#6 posted 09-10-2018 01:18 PM
- Steve
^^ This. However, I’ve found my workstation is heavy enough that I hardly ever need to lock the casters. It reminds me of football practice back in high school when we had to push around the blocking sled.
-- Tony, SW Chicago Suburbs
View MrRon's profile
MrRon
5812 posts in 3852 days
#7 posted 09-10-2018 03:32 PM
I find the problem with locking casters is; you can never get all 4 casters in a position where all the brakes can be applied. This is true of small casters, those around 3 or 4”. Large casters, like the ones used on hospital gurneys are accessible for locking, but the smaller ones get hidden under the framework and don’t leave enough access for your foot. At best, only 2 casters can be locked and it still takes some maneuvering to get the platform into locking position. So, what is the solution? Use retractable casters that allow the platform to rest solidly on the floor.They cost a lot more. Moving the casters toward the center of the load really doesn’t answer the problem. By placing them at “far corners”, increases stability as table saws tend to be top heavy. I would not use more than 4 casters. When I built a platform for my cabinet saw, I wanted to use large casters, like 5”, but that would place the saw top too high above the floor, so I made the platform to accommodate 5” casters, by welding offset pieces at each corner. That kept the top 36” above the floor. Recently, I finalized the position of the saw in my shop and have discarded the mobile base. I hope some of this helps you.
emilime75
#8 posted 09-10-2018 05:03 PM
I don’t see why moving the casters inwards would decrease stability, and by moving inwards I mean side to side, not front and back. The 2 front and 2 rear casters would still be at the outer edges of the base, but instead of having them at the far left and far right ends, I’d move them in closer to center by roughly 18-20”, placing them roughly 40-44” apart from each other.
Then combined weight of the 2 saws will primarily be in the center of the workstation and take up about 40” of it, so I don’t see the possibility of it tipping when working a heavy project or stock on either the left or right end.
Rick Dennington
#9 posted 09-10-2018 06:31 PM
If you go back and look at my saw station, you’ll see that I had removed the casters in the middle of the platform, and just used the ones on the outer edges of the platform….I then added levelers to each of the corners to adjust the height of the cabinet….My out feed table is between my two saws, and neither one of them moves….The levelers help stabilize the cabinet, and makes the height where I need it to be level…..The casters do not move unless I want to move the saw, in which case I don’t…..Only to check the oil in the motor, or change a belt out….or check the pullys…...So some things that some people tell you just doesn’t hold water….It’s your saw station…...do it like you want to…..!!
View Kaleb the Swede's profile
Kaleb the Swede
1916 posts in 2578 days
#10 posted 09-10-2018 06:38 PM
The one I made for mine uses 6 casters. (I didn’t post it as a project). I use 2 on either end and 2 i the middle. I have a craftsman 21833 saw and a router on the left wing. The rest I made into storage.
I’ll try and take a picture later tonight. My thought is for the weight you are projecting, would be to have something in the middle also.
-- Just trying to build something beautiful
View RyanBWood's profile
RyanBWood
8 posts in 502 days
#11 posted 09-10-2018 07:21 PM
I made one for my delta saw with 6 casters.
The base is an open torsion box underneath. if you think of a torsion box without one of the panels. I made the base from a 3/4 birch ply and 3/4 torsion frame all glued together. no screws except for the outside frame. I then put 1 caster in each outside corner inside one of the torsion box holes. Then another 2 in the middle on the outside of the frame.
I then just capped it with a 3/4 cedar panel for aesthetics
Locking in place was easier with just 4 toggle clamps. see in picture. the ends can be hand adjusted for height to lock the roller base anywhere in my garage… which does not have a level floor due to a floor drain in the middle of the floor. depending where I use the saw, the toggle clamps have to be adjusted to where it sits.
Most of the time i only use the 2 front toggles to keep it in place. there are 2 more on the back side outer corners, but are rarely needed
Having 6 wheels does make it rock sometimes when moving around, but all 6 rotate and it just takes a little man handling to get it into the place I want it..
So far i have been using it a couple years without issue. added more cabinets and storage to it as well as dust collection and a folding outfeed table.
it caries a lot of weight and still moves easily.
-- Full time kid chauffeur, woodworking on the side.
RyanBWood
8 posts in 502 days
#12 posted 09-11-2018 04:50 PM
Also, as for the racking or twist. there is none. the base is so stiff that as I move it around, it may rock on 3 or 4 casters . the base does not bend at all.
if you put bigger toggle clamps on it, you can lift the entire unit off the ground and with enough adjustments actually level it on a non-level floor.
View BlasterStumps's profile (online now)
BlasterStumps
1497 posts in 1048 days
#13 posted 09-11-2018 07:49 PM
If I was to build a mobile station for my tablesaw, router and have storage on it as well, I would look into building the base with a torsion box. I have a cabinet under my drill press that I built with a torsion box frame. There is no room for casters except on the outside corners. It’s one heavy son-a-gun but doesn’t sag anywhere and the casters work fine.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
