Opinion on Router choice
Forum topic by mknittle posted 09-07-2018 03:41 PM 371 views 0 times favorited 4 replies Add to Favorites Watch
View mknittle's profile
mknittle
9 posts in 616 days
09-07-2018 03:41 PM
I have a 1617EVS PK (kit) that the motor is going to live in A router table. Now I am thinking about another router for handheld use. I have narrowed my choices down to two either another Bosch 1617 EVK with just the fixed base or the Dewalt DWP611 PK (kit) The Dewalt is only $10 more at Home Cheapo. I have some thoughts on this but want to toss it out there and see what others think Thanks ,Mark
View ChefHDAN's profile
ChefHDAN
1496 posts in 3454 days
#1 posted 09-07-2018 04:40 PM
Mark,
I have the DWP611 kit and love it, the led light is incredibly handy at times. The pieces move easily between the bases and my PC edge guide fits, (but is big and bulky). Just finished a redo of all the cabinet doors & drawers in the kitchen. Found a pawnshop PC 690 to add so that I could have 3 routers set for the doors, Stick, Cope, and Panel. There were so many to do I didn’t want to change any bits during the process. The 611 was fitted with a round over and it was a breeze to do both sides of everything on a grip mat.
Only downside is the 1/4” collet. Over the years I primarily have only bought 1/2” so I’ve had to get some edge forming profiles in 1/4”, and some spirals for mortises and hinge plates etc. This little one makes it real easy to eyeball roughing out a mortise and then just coming back with a chisel to cut to the line.
If you can easily drop your bosch motor to still use the kit bases (my PC’s are attached to the plate but still have their handles), then I think you’re safe with the 611. If your motor is going into a lift that won’t be as simple to use the motor I’d say go with another bosch, although Id really recommend getting a 3 hp for the table too….
View mathguy1981's profile
mathguy1981
94 posts in 508 days
#2 posted 09-07-2018 04:48 PM
Go with another Bosch. I am having the exact same search/dilemma right now and I’m going to go with another 2.25 HP fixed handle Bosch.
-- Two thumbs and counting
5924 posts in 3097 days
#3 posted 09-07-2018 05:30 PM
I’d also stay with the 1617, it pays to have interchangeability between your routers. Besides, as mentioned above the Dewalt is a 1/4” router.
View CaptainKlutz's profile
CaptainKlutz
2216 posts in 2098 days
#4 posted 09-07-2018 07:48 PM
+1 Dewalt 611 kit is very useful for hand routing.
It is one I reach for 90% of time when hand routing; and I own 6 routers from 4 different mfg, including (2) Bosch 1617. The built in light on 611 is very useful when hand routing. Find that I use the router table as much as possible for shaping edges, as it collects debris and keeps shop cleaner; so amount of router use by hand is fairly small?
As Chef posted, the 611 has only 1/4 inch shank. So don’t expect 611 to spin a heavy 2+ inch diameter bit and take deep cuts, like cutting rail/stile. Was worried as majority of my bits were 1/2 inch shank. Due limited amount of hand routing actually done once I had router table, only needed about a few 1/4 inch shank bits. I’d guess 60% of time my 611 is using round over bits, maybe 30% time is spiral or straight cut bit following a template.
Thinking back since I bought my 611 a few years ago; can only remember one use where I needed a bigger router? Was making router bowls. For them, I spin a 1-1/4 inch diameter bowl/dish bit hogging out a 3 inch deep block of wood with a bit extension. Used my Bosch 1617 plunge base with larger custom base plate.
Best Regards.
