Dye stain drip - Help me fix it?
Forum topic by cracknpop posted 09-06-2018 01:41 AM 919 views 0 times favorited 18 replies Add to Favorites Watch
View cracknpop's profile
cracknpop
381 posts in 2950 days
09-06-2018 01:41 AM
Topic tags/keywords: question cherry finishing dye
General Finishes Vintage Cherry Water Base Dye Stain over Charles Neil’s Per-Color Conditioner on cherry. Stained bottom of lid first. Flipped it over stained top. Missed a running drip!!!! GRRRRR!!!!!
Recommendations on how to fix? Unfortunately I’m on a tight schedule.
-- Rick - I know I am not perfect, but I will keep pressing on toward the goal of becoming all I am called to be.
18 replies so far
View TheFridge's profile
TheFridge
10859 posts in 2088 days
#1 posted 09-06-2018 01:49 AM
Sorry no help. I’m curious as well. I might try some very selective scraping.
117905 posts in 4179 days
#2 posted 09-06-2018 03:07 AM
You already said the person’s name with the best solution, Ask Charles Neil.
View lumbering_on's profile
lumbering_on
578 posts in 1091 days
#3 posted 09-06-2018 03:14 AM
In IT we’d call it a feature, but I don’t think that would work here.
If you do find an answer, would you be able to post it so others would be able to fix it in the future?
cracknpop
#4 posted 09-06-2018 03:38 AM
You already said the person s name with the best solution, Ask Charles Neil.
- a1Jim
Great suggestion… just sent him a personal message.
I will mention, this is the first time using his conditioner… NO blotching!!!!
View therealSteveN's profile
therealSteveN
4589 posts in 1176 days
#5 posted 09-06-2018 03:50 AM
(414) 426-0194
General Finishes, Phone
Nice people, they want you to be happy with their products. If they don’t know how, nobody knows how
-- Think safe, be safe
View CharlesNeil's profile
CharlesNeil
2501 posts in 4472 days
#6 posted 09-06-2018 11:33 AM
This is a tough fix , is it sprayed or wiped on ?
View Kazooman's profile
Kazooman
1408 posts in 2554 days
#7 posted 09-06-2018 01:00 PM
Did you trying wiping it with a wet rag? It looks like a lot of the dye is just sitting on the surface. It might wash off. The preconditioner might have prevented too much penetration, if you are (very) lucky. At least removing any surface dye that will dissolve will be a start on any more elaborate fix.
View Robert's profile
Robert
3598 posts in 2082 days
#8 posted 09-06-2018 01:37 PM
Water or alcohol with a little steel wood and redye the whole top?
Waiting for Charles’ answer…..................
cracknpop
#9 posted 09-06-2018 03:00 PM
- CharlesNeil
This was wiped on. Wiped on the bottom of the lid first. Had let it dry while stained rest of project. When I flipped it over to stain the top of the lid, found the drip. Had hoped wiping the dye stain on the top would feather it out, but unfortunately not.
I appreciate your help.
View waho6o9's profile
waho6o9
8811 posts in 3178 days
#10 posted 09-06-2018 03:08 PM
I’d run it through the shaper again and take a light cut.
View GR8HUNTER's profile
GR8HUNTER
6797 posts in 1314 days
#11 posted 09-06-2018 03:36 PM
OUCH …. what about a card scraper ? :<))
View bonesbr549's profile
bonesbr549
1586 posts in 3669 days
#12 posted 09-06-2018 03:51 PM
if it’s dye, why not just get some contour sanders and take it off & redo? Probably looking too simplistically at this, but elbow grease would be my shot at it? (but that opinion and a buck fifty will get you a cup of coffee)
Good luck.
cracknpop
#13 posted 09-07-2018 12:01 PM
Based on some of the feedback so far, I am considering spraying a seal coat on the whole top, I typically use lacquer. Then run the end with the drip through the router just shaving off the finish to raw wood. Then repeat the original sanding, CN’s pre-color conditioner, dye stain just to the end of the top.
Is that a workable option or should I be considering something else?
waho6o9
#14 posted 09-07-2018 12:10 PM
Good idea cracknpop.
CharlesNeil
#15 posted 09-07-2018 12:35 PM
crackenpop
You read my mind, your plan sounds like a very viable solution, i agree
keep us posted
