Replacement for Record No 7 lateral adjustment lever
« back to Hand Tools forum
Forum topic by Matlanta posted 09-05-2018 12:31 PM 498 views 0 times favorited 9 replies Add to Favorites Watch
View Matlanta's profile
Matlanta
4 posts in 508 days
09-05-2018 12:31 PM
Topic tags/keywords: plane record
I’ve got a Record No. 07 jointer plane and the lateral adjustment lever is worn and surprise…lateral adjustment isn’t working too well (because it is not contacting the plane iron with as much friction). Does anyone know if other manufactures’ levers are compatible with Record. For instance could I swap out the lever for a Stanley lever?
Thanks, Matt
9 replies so far
View WayneC's profile
WayneC
14358 posts in 4707 days
#1 posted 09-05-2018 12:58 PM
Normally, I would just swap the frog.
Matlanta
4 posts in 508 days
#2 posted 09-05-2018 01:06 PM
Thanks Wayne I thought about swapping the whole frog, but I’d have to find one. Its a lot easier to find Stanley frogs than Record (in the US). Im not sure if frogs from a Record 4,5,or might be interchangeable with the 7.
View Mr_Pink's profile
Mr_Pink
184 posts in 981 days
#3 posted 09-05-2018 01:13 PM
You could always replace the lateral adjustment lever with lateral adjustment taps from a small hammer.
WayneC
#4 posted 09-05-2018 01:36 PM
Interchangeable frogs are 4 1/2, probably 5 1/2 ( Width variance in early Stanley frogs that I’m thinking does not apply to record), 6 and 7. Is the issue a loose lateral lever or is the tab worn that fits in the cutter?
Matlanta
4 posts in 508 days
#5 posted 09-05-2018 02:54 PM
The lever is loose, because the circular pad that pushes on the iron is worn down. OK I can probably find a Stanley 4 1/2 or 5 1/2 frog on eBay for relatively low cost. All the Record frogs for sale are from UK sellers. Thanks!
WayneC
#6 posted 09-05-2018 03:16 PM
I don’t think a stanley would fit. Look for a rough record parts plane. #6 would be most likely. But, something like this
https://www.ebay.com/itm/VINTAGE-RECORD-NO-4-1-2-PLANE-MADE-IN-ENGLAND/292703160276?hash=item442677c7d4:g:mG0AAOSwybpbhyry
WayneC
#7 posted 09-05-2018 03:17 PM
Also, check with the guys in the handplane thread…. One of them may have a frog.
http://lumberjocks.com/topics/235737
View TheFridge's profile
TheFridge
10859 posts in 2096 days
#8 posted 09-05-2018 03:45 PM
are Any of the rivets loose? I ask because I’ve never seen that circular part ever wear out.
Matlanta
4 posts in 508 days
#9 posted 09-05-2018 04:51 PM
Thanks everyone..no loose rivets, the disc at the bottom of the lever is worn thinner than it should be. I think someone filed it down but who knows.
