gluing down measuring tape
Forum topic by Karda posted 09-03-2018 09:42 PM 1919 views 0 times favorited 18 replies Add to Favorites Watch
View Karda's profile
Karda
1963 posts in 1159 days
09-03-2018 09:42 PM
Hi, i made a circle jig for my band saw. I mad an adjustable pin. I want to glue down a seamstress tape for a measure what should i use for glue. I looked into preadhesive and they are expensive and then add shipping. The price is good on the ones from china but the wait is long. any Ideas
18 replies so far
View waho6o9's profile
waho6o9
8812 posts in 3182 days
#1 posted 09-03-2018 09:44 PM
View John Smith's profile
John Smith
2133 posts in 768 days
#2 posted 09-03-2018 10:11 PM
assuming you are talking about a wooden jig ??
since you are not going to glue down the whole 6 feet of tape,
why not experiment with some of it ?? personally, I would use yellow glue for A wooden jig….
for a jig with a laminate or plastic top, I would use contact cement.
-- I am a painter. That's what I do. I paint things --
Karda
#3 posted 09-03-2018 10:26 PM
ok thanks that is a good site to have. Some sewing Tapes are coated what then
View higtron's profile
higtron
253 posts in 3283 days
#4 posted 09-03-2018 10:36 PM
$7.49 for 12’ of psa measuring tape doesn’t sound that extravagant to me https://www.maxtool.com/kreg-12-self-adhesive-measuring-tape-r-l-reading?google=1&CAWELAID=230005740000001427&CAGPSPN=pla&CAAGID=19685619371&CATCI=pla-107150043851&gclid=EAIaIQobChMI94_h0_Gf3QIVi8BkCh2HBglpEAYYCCABEgKqLfD_BwE
-- A friend will help you move, a good friend will help you move a body
View joabraun's profile
joabraun
7 posts in 1962 days
#5 posted 09-03-2018 10:59 PM
That sewing tape is not very accurate, you may want to compare it to something you know is accurate
View LesB's profile
LesB
2308 posts in 4049 days
#6 posted 09-03-2018 11:41 PM
If your are gluing down “seamstress” tape I would use spray adhesive. One coat on the back of the tape and mask off with painters tape the area you want to glue it to and apply the adhesive there. When they get tacky put them together. If you need to replace it just warm it up with a heat gun and it should come off.
Of course you could just “draw” you own measurements marks on the jig. That would be almost “free”.
-- Les B, Oregon
Karda
#7 posted 09-04-2018 12:25 AM
Thanks for your suggestions,
View gwilki's profile
gwilki
330 posts in 2079 days
#8 posted 09-04-2018 01:44 AM
double sided carpet tape
-- Grant Wilkinson, Ottawa ON
Karda
#9 posted 09-04-2018 03:04 AM
thats an idea
View GrantA's profile
GrantA
2125 posts in 2013 days
#10 posted 09-04-2018 12:57 PM
$5.44 and prime shipping, and it’s Starrett https://www.amazon.com/dp/B0025Q0KAC/ref=cm_sw_r_cp_api_4cOJBbTS86D6K
View Lazyman's profile
Lazyman
4502 posts in 1993 days
#11 posted 09-04-2018 01:12 PM
$5.44 and prime shipping, and it s Starrett https://www.amazon.com/dp/B0025Q0KAC/ref=cm_sw_r_cp_api_4cOJBbTS86D6K
- GrantA
+1. Only a little more expensive and much more accurate, though because it is metal, it may expand and contract a little with temperature changes. Since you are applying to wood, I would apply paint or poly first to make it stick better.
Karda
#12 posted 09-04-2018 03:23 PM
yea I saw that but I don’t have a prime account, and I couldn’t find out what the shipping is. I saw one about that price with 16.45 shipping from Ill. I won’t order if I don’t know shipping. I bit the dust and ordered one
View Bill_Steele's profile
Bill_Steele
633 posts in 2337 days
#13 posted 09-04-2018 03:43 PM
What about construction adhesive? I’ll bet construction adhesive on that sewing tape measure would hold it down. Locktite makes some stuff that does NOT require one of the surfaces to be porous.
View MrRon's profile
MrRon
5810 posts in 3849 days
#14 posted 09-04-2018 09:05 PM
If the tape is glued to the top of the circle jig, won’t it interfere with the workpiece by not letting it be 100% in contact with the jig? I would just layout a scale with a ballpoint pen.
MrRon
#15 posted 09-04-2018 09:06 PM
