Delta Bandsaw Parts
Forum topic by Steve5461 posted 09-03-2018 08:56 PM 526 views 0 times favorited 5 replies Add to Favorites Watch
View Steve5461's profile
Steve5461
2 posts in 512 days
09-03-2018 08:56 PM
Blade tensioning threaded shaft and nut on my Delta 28-280 Band Saw are stripped and I have not been able to find replacement parts online. Anyone had this problem, and, if so, any luck in finding replacement parts. Part 24, Knob Assembly, No. 426-02-412-0008 in particular seems to no longer be manufactured.
5 replies so far
View MrUnix's profile
MrUnix
7601 posts in 2810 days
#1 posted 09-03-2018 09:24 PM
If you can’t find an OEM replacement from the various aftermarket suppliers or flea-bay, you can always just replace it with a piece of 3/8”-16tpi all thread. How to work out the handle portion will need a bit of tinkering, but I can think of several different ways to do it – from using recycled milk jugs (HDPE), on up through making it functional with a 3/8” ratchet.
Steve5461
2 posts in 512 days
#2 posted 09-03-2018 09:46 PM
The handle I can handle! I think the square nut is available online.
Thank you for the assistance.
View Knockonit's profile
Knockonit
643 posts in 813 days
#3 posted 09-03-2018 11:30 PM
for an old jig i had i needed some square nuts, so i just bought some 1/4’’ steel, drilled the holes, tapped them and cut them out for square nuts, was a bit of work, but kept me from burning up the tires and the internet looking for them, and one can’t hardly tell difference
best of luck, hate it when delta doesn’t support the older stuff.
ugh
-- Living the dream
View TheFridge's profile
TheFridge
10859 posts in 2097 days
#4 posted 09-03-2018 11:30 PM
I’ve have great luck with eBay as well.
View Gart's profile
Gart
29 posts in 2028 days
#5 posted 09-18-2018 11:14 PM
Are you still looking for these parts?
I replaced mine with this LINK
I can look in the garage and see if I can find the parts that I took off the saw.
