Will Zinsser Sealcoat (Dewaxed Shellac) seal tannins??
Forum topic by Kaitlin53 posted 09-01-2018 01:58 PM 1112 views 0 times favorited 10 replies Add to Favorites Watch
View Kaitlin53's profile
Kaitlin53
4 posts in 514 days
09-01-2018 01:58 PM
Topic tags/keywords: pine zinsser sealcoat sealer question
Hi,
I’m still new to woodworking (roughly 2 years) and am now facing a problem. I make wooden signs and lately the farmhouse look has been a hit. (Think stained wood, with dry-brushed white latex paint on top, sanded to look worn.) I had never heard of tannins until recently when I researched why the beautiful sign I made my sister had a brown “stain” on it. I’m now at my wits end with these.
I tried the Zinsser BIN Shellac based and it still had a yellowish tint to the white paint.
Will the Zinsser Sealcoat seal in the tannins? It sounds like it should logically.
I don’t really want to use white because I also use other colors, like a light gray. Is there anything on the market, clear-colored, that will seal in tannins on raw pine…before I lose my mind?
Thank you all for any help.
10 replies so far
View Planeman40's profile
Planeman40
1473 posts in 3372 days
#1 posted 09-01-2018 02:42 PM
Shellac will seal in about anything in wood. I don’t know about “tannins”, but I know it will seal knots in pine paneling to keep the rosin from showing through. Great stuff shellac. I don’t think it would do well outdoors though. It would have to have a good top coat like outdoor polyurethane for outdoor use.
View Bill White's profile
Bill White
5242 posts in 4571 days
#2 posted 09-01-2018 02:55 PM
What wood are you using for the signs? If it is pine, you’re getting the “sappy” bleed-through native to the specie.
Sealcoat will be a BIG improvement, and exterior paint (whatever color) is a must. Outdoor/marine poly is gonna give you a yellow cast to the finish. Water based poly won’t.
-- [email protected]
5932 posts in 3104 days
#3 posted 09-01-2018 03:21 PM
My answer would have been “yes, use the sealcoat”. But if you used the BIN primer and it didn’t work, I can’t help but think the sealcoat won’t work either. Regardless, as pointed out above it doesn’t do well outdoors so it might not be the solution you need anyway. I think I would try an oil based primer and see if that solves your problem.
View Aj2's profile
Aj2
2656 posts in 2409 days
#4 posted 09-01-2018 03:21 PM
What’s wrong with bleed through on a farmhouse sign.
Doesn’t sound like it should be a problem.
If that’s the folk art look anything goes::)
-- Aj
Kaitlin53
4 posts in 514 days
#5 posted 09-01-2018 03:23 PM
I use pine and most of my signs are for outdoor use like for covered porches. Not directly in the sun or weather, etc.
I do use the Helmsman Spar Urethane to finish them, but the yellowing was occurring before I ever got to that point.
“Exterior paint is a must”. I’ve been using either acrylic or indoor latex. Would the spar urethane not do its job in sealing acrylic or indoor latex? Honest question.
Kaitlin53
4 posts in 514 days
#6 posted 09-01-2018 03:26 PM
AJ, true. Haha. It’s just not expected and looks like a stain, and not a ‘cool’ vintage thing going on.
Kaitlin53
4 posts in 514 days
#7 posted 09-01-2018 03:28 PM
What happens to the Sealcoat if it’s used outdoors? Why doesn’t it do well outdoors?
#8 posted 09-01-2018 05:57 PM
I’m not sure what the breakdown is, but shellac has never been a very durable use in the outdoors, even under paint it will fail.
View Aj2's profile
Aj2
#9 posted 09-01-2018 08:41 PM
Some woodworker will build a table and say how do I stain this table to make it beautiful.
Other times someone will make something and say it has a stain how do I get rid of it to make it beautiful.
Maybe beauty is in the eye of the beholder and not the maker ???
-- Aj
bandit571
24436 posts in 3294 days
#10 posted 09-01-2018 09:52 PM
Maybe look into using KILZ Primers….?
