Patching 1/8" gap with wood filler?
Forum topic by boobird posted 08-30-2018 12:53 AM 1323 views 0 times favorited 20 replies Add to Favorites Watch
View boobird's profile
boobird
12 posts in 518 days
08-30-2018 12:53 AM
My first attempt at making a shaker cabinet door…
Took a 1/2” plywood panel and rabbeted 3/8” so that it will slide in a groove. But it’s not a perfect fit.
There is a 1/8” gap between the plywood and the stile piece.
Can i patch this long 1/8” gap with some type of filler? What would be the most durable material to use? Please also consider the ease of use, # of coats required, sandability, hardness etc
Readypatch?
Wood filler?
Bondo?
Elmer’s wood filler
Durham’s
From.bobvila.com
My cabinet door as seen from the back
I will be priming and painting white.
20 replies so far
View rickinbeachcrest's profile
rickinbeachcrest
16 posts in 2084 days
#1 posted 08-30-2018 01:41 AM
IMHO, Wood putty or any of its ilk, have no business in fine woodworking.
I would take a 45 deg router bit and run it along all 4 edges and make it look like you did this on purpose.
13694 posts in 3943 days
#2 posted 08-30-2018 02:01 AM
i’ve used bondo for various needs
solid filler
good glue too
tape the back if the fix is all the way thru
put some from the back after the main has hardened
if needed
sand and repeat till it is nice and smooth
more hardener
is kicks faster
thats how the auto body shops do it
maybe some cream after for any slight imperfections
to final smooth
paint
View sras's profile
sras
5284 posts in 3731 days
#3 posted 08-30-2018 03:15 AM
Fill with a thin strip of the same wood. The gap will disappear.
View TravisH's profile
TravisH
700 posts in 2537 days
#4 posted 08-30-2018 11:14 AM
Durham’s likely your best option if going fill route with a “paste” type product.
I have used it to patch a board outdoors that our dog decided was a good thing to chew on years ago. No issues to this date and it has been exposed to -16 to 100 degree temperatures, rain, and sun for about 10 years now. The surface was much rougher to begin with however. It also was covered with a good exterior paint.
I would likely however not fill as see it hard that you won’t get small hairline cracks in time on a door that will telegraph the old design. Not for sure about tools you have available but a router and sled set up and you could just make a square recessed shaker door look rather easy.
View ArtMann's profile
ArtMann
1462 posts in 1418 days
#5 posted 08-30-2018 03:33 PM
You may have problems with hard material cracking, separating and even coming out due to differential expansion between plywood and solid wood. I know it sounds wrong but I would use painters caulk because it is flexible and will move with the material throughout the year. You have that freedon since you are painting.
boobird
#6 posted 08-30-2018 03:38 PM
Thanks for the replies.
This is the first time i’ve ever used a table saw, router, etc.
When I was using the router table + tongue/groove bit, I had trouble keeping it flush against the fence.
When using a router table, is it safe to use the fence AND a miter gauge? I found that the miter gauge kept the rail piece perpendicular to the bit (when creating the tongue). without the miter gauge pushing along the rail, the piece kind of dipped into the bit and took a chunk out.
boobird
#7 posted 08-30-2018 03:43 PM
I obviously didn’t measure the center plywood panel correctly! I didn’t visualize that the back panel would sit directly flush with the back rail/stiles.
View Robert's profile
Robert
3598 posts in 2083 days
#8 posted 08-30-2018 03:57 PM
Bondo.
Or live with a defect on the back of a door…............... :-)
Couple things: 1. Use a push block rather than a miter gauge on the rail ends. I screw one of those cheap plastic ones a piece of wood that serves also as a backer to prevent tear out. Be sure the piece of wood is a perfect 90° so it holds the rail ends square to bit.
2. Feather boards help guide the more precisely through the bit.
3. An insert in your fence that is cut out to match the router bit. This keeps the gaps to a minimum to the wood engages the guide bearing right away.
- boobird
View AlaskaGuy's profile
AlaskaGuy
5516 posts in 2911 days
#9 posted 08-30-2018 04:29 PM
If you are talking about a gap on the back of the door where the panel goes slides into the groves of the styles and rails.
Since it looks like your using plywood panels you won’t any appreciable movement. I would secure the panel with a couple of short pin nails from the back side, then Id run a bead of flexible paintable caulk around the door.
View Rich's profile
Rich
5132 posts in 1191 days
#10 posted 08-30-2018 04:31 PM
- boobird
Buy or build a coping sled. I have a small one I use for coping rail ends on cabinet doors and a really large one I use for residential door rails, where the kick rail is 9”-plus.
Here’s the large one. It rides in the miter slots of the table saw (the router is in an extension wing):
AlaskaGuy
#11 posted 08-30-2018 04:38 PM
- rickinbeachcrest
No harm, no foul in using fillers in/on painted projects. The professions do it all the time.
boobird
#12 posted 08-30-2018 04:47 PM
Is it actually possible to have perfectly smooth painters caulk? It seems too viscous and impossible to sand down? Unless you’re not talking about alex caulk..?
AlaskaGuy
#13 posted 08-30-2018 04:56 PM
Is it actually possible to have perfectly smooth painters caulk? It seems too viscous and impossible to sand down? Unless you re not talking about alex caulk..?
- boobird
https://youtu.be/siDYA3WdO8M
https://youtu.be/OmMlDMCOICk
https://www.youtube.com/results?search_query=caulking+cabinets+before+painting+
View bandit571's profile
bandit571
24350 posts in 3285 days
#14 posted 08-30-2018 05:01 PM
Just use the same thing painters do with caulk…..a wet finger. Nothing complicated.
boobird
#15 posted 08-30-2018 05:03 PM
My concern with caulk would be requiring some kind of backer rod, since the gap is rather large.
And also, it may not be perfectly flat because its not sandable?
