Forum topic by EBreindel | posted 08-29-2018 01:12 PM | 1181 views | 0 times favorited | 21 replies | ![]() |
Hello, I am trying to set up a shop. I have a standard two car garage (one garage door) I have seen many options for dividers for a two car garage with two doors but no so much for one door. My wife will be parking her car on the other side and doesn’t want sawdust all over on her side. Anybody have any ideas?? Thank you |
21 replies so far
#1 posted 08-29-2018 01:31 PM |
Find her another place to park then you get the whole garage! Seriously if she doesn’t want sawdust then your options are either make the sawdust outside and blow off everything before bringing it back in, or get a big dust collector and the best ports/guards/enclosures for the tools. |
#2 posted 08-29-2018 01:59 PM |
I’d just play valet and move her car around. Can’t imagine cutting my workspace in half…. -- I've decided 1 mistake is really 2 opportunities to learn.. learn how to fix it... and learn how to not repeat it |
#3 posted 08-29-2018 02:22 PM |
I’ve actually been thinking about a solution for this myself – haven’t done it yet, but i was thinking about using some 3/4” black pipe (only reason for that specifically is that it’s the only one I could seem to find the right fittings), a combination of tees and flanges, and screwing it into the rafters of the garage to make a “curtain rod”. I was thinking that some tarp that hangs down to the floor, with probably some sort of weight at the bottom, would hold it in place while working -when I’m done, it would be easy enough to slide/unhook until the next time. kind of like this – (looks like they used cable on this one instead of pipe) |
#4 posted 08-29-2018 02:43 PM |
Unless you build a solid wall some dust will inevitably wind up on the other side so be prepared for some complaints. A leaf blower will help you blow any dust that does make it over there. These are probably too pricey but you might get some DIY ideas by looking. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#5 posted 08-29-2018 05:54 PM |
I’d go with a curtain. If the car side is such that opening the car door is towards the curtain, so much the better. While you have to have enough room to walk between the car and curtain, it wouldn’t matter if the car door hits the curtain a bit, assuming you don’t place something solid on the other side of the curtain. Before going all DIY with things like pipes and fittings for hanger rods, I’d look into purpose built tracks for curtains. The type of thing you see in hospitals. Obviously as close to the the ceiling as you can hang it. That’s why I wonder if there isn’t a track you can get and some sort of hangers that go right at the top edge of the curtain. Might even be a way to have the curtain rub the ceiling. It would likely be best to touch the floor. Dust settles and you walk around kicking it up. Nice thing about a curtain is you can pull it out of the way when you need more room. I agree with dust collection and I’d hang a room filter in the shop side. Remember, if dust can settle on things it also means you will be breathing it. So the same things that make it safer for your lungs will also greatly reduce the dust problem. -- Clin |
#6 posted 08-29-2018 09:55 PM |
I couldn’t find a solution that worked well so I have everything on mobile bases. -- When you leave your shop for the night, make sure you can always count to 10. |
#7 posted 08-13-2019 07:42 PM |
I had a project building benches for my husbands microbrewery and ran into terrible dust problems, if you eliminate the track and get something like pipe stock from Home Depot here, it cuts the cost way down. We got our Garage Curtains from Steel Guard Safety but I know there are several manufactures that sell them. The Curtains we have had about 6 months do a pretty good job of keeping the dust out of our cars that are garaged. Cost only came to about $17-18 a foot. |
#8 posted 08-13-2019 07:47 PM |
Sawdust is very lightweight and non-adhesive. Any that lands on her car be blown off before she even makes it to the street. Otherwise, I’d go with the leaf-blower. If you need to keep other things contained, a divider may be necessary but, IMO it’s easier to get sawdust off a vehicle than it is to keep it off. -- Kenny, SW VA, Go Hokies!!! |
#9 posted 08-13-2019 10:06 PM |
i just let her complain then i build her what she wants,she still complains but accepts the fact that’s life in a woodshop.good luck. -- sawdust the bigger the pile the bigger my smile-larry,so cal. |
#10 posted 08-13-2019 10:07 PM |
There is a steel channel for electrical work that can screw to the ceiling. They make wheeled dollies that fit inside the track and roll nicely. I have a drop cord and air hose attached to the track in my garage. The channel is made by Unistrut, also by B Line and others. Comes in 10’ and 20 ’ lengths with the holes pre punched in it. Easy. Better than pipe and fittings because it mounts tight to the ceiling. |
#11 posted 08-14-2019 12:02 AM |
I used to make a ‘paint booth’ in the corner of my garage that looked similar. I used 10’ long sections of 3/4” metal electrical conduit and an eye bolt big enough that the conduit could slide through. The conduit only needed to be supported at both ends, and I would image to split a garage like that you could do it with two pieces, a connector and 3 eye bolts. I then bough some extra long, clear shower curtains from Amazon, and it actually worked out pretty well These are 6’ x 8’ |
#12 posted 08-14-2019 12:20 AM |
Good luck on your dilemma. I just sanded a farmhouse table today with a belt sander and got dust all over my wife’s car. I bet she will say something to me about it. |
#13 posted 08-14-2019 12:31 AM |
My wife parks in my shop, and the dust hasn’t been an issue. My tools are always hooked up to either a dust collector or a shop vac. Circular sawing and free hand routing I’ll do outside. At the end of the day I do a quick vacuum of the floor. No complaints from my wife. Just take you wife’s car through the car-wash once in a while and make sure her tank is full. -- Kjell - Eau Claire WI |
#14 posted 12-04-2019 08:07 PM |
I think you are going a bit too light with that track. We went to McMaster to seal up the gap between the track and top of the garage with some material and velcro swatches cut up. When looking around I saw a similar curtain hooks much cheaper here at McMaster Curtain Hooks only $5 for 10. You could buy the Material and make your own, but I know when I called back Steel Guard they said they have B Stock Body Shop Curtains for sale a lot. Didn’t need any just got a few yards of material to stop the saw dust from leaking out plus velcro. |
#15 posted 12-04-2019 08:17 PM |
if the garage is finished, frame a wall to divide the 2 areas and drywall it. |
Forum | Topics |
Woodworking Skill Share
12691 |
Woodturning
2569 |
Woodcarving
514 |
Scrollsawing
377 |
Joinery
1659 |
Finishing
5771 |
7376 |
30718 |
CNC Woodworking
268 |
Hand Tools
5985 |
Jigs & Fixtures
1624 |
Wood & Lumber
6836 |
1515 |
Focus on the Workspace
2414 |
1230 |
Woodworking Trade & Swap
5145 |
LumberJocks.com Site Feedback
2320 |
Coffee Lounge
9345 |
