Real Crappy wood WIP
« back to Woodturning forum
Forum topic by Nubsnstubs posted 08-25-2018 04:00 PM 652 views 0 times favorited 3 replies Add to Favorites Watch
View Nubsnstubs's profile
Nubsnstubs
1659 posts in 2331 days
08-25-2018 04:00 PM
Topic tags/keywords: crappy wood mesquite burl burl root old wood turning crappy wood
Yesterday I went back to a piece I started about a couple years ago. It is Mesquite root burl that I got near Prescott, Arizona. It has probably been dead over 50 years as there was only the stump was left. I really don’t know when or what the heck caused me earlier to turn a 3” tenon as I don’t have any jaws that size. It had to be remounted in order to make a tenon I could use. Nothing aligned, so had to start over and try to save some of the existing tenon that was already there. So, I got it between centers, and started to turn.
What I used for the driver.
Mounted!! I used my nose ring with my live center to assist with mounting it securely between centers. Notice the larger tenon and how it’s offset. I have no clue how it was done awhile back.
Re-turning the tenon was pretty easy. Notice my Nova chuck jaws that are said to be 75 mm. 2 9/16’ is about as far as they go. Also notice the Nose Ring in the left bottom corner. With out it, I couldn’t possibly turn as many crappy pieces that I do.
It’s remounted. My issue now is how to set up the tool rest and still be able th turn the inside. It took awhile, but I managed it.
I used my Easy Wood CI5 to do most as it was small enough and I’d just put on a new cutter. If you look closely near the center, you should be able to see the end of the tool.
It was a piece of cake until a few minutes later, I pulled the tool out and caught it in such a manner that it came out of the jaws. No harm done as I was not in the “line of fire”. Actually, the tool rest and low speed kept it from flying.
I turned it for about another hour, and had to call it quits as it was kicking my butte I will post more later when I finish it today. ................ Jerry (in Tucson
3 replies so far
View LeeMills's profile
LeeMills
688 posts in 1903 days
#1 posted 08-25-2018 05:14 PM
Notice my Nova chuck jaws that are said to be 75 mm. 2 9/16 is about as far as they go.
That is pretty close to the specifications by Nova. 2 9/16 = 2.5625 Nova states 2.657 or a difference of about .094 from your measurement.
Like all Nova Bowl jaws, their sizing is by the exterior. They should be 75 mm exterior when closed.
View 000's profile
000
2859 posts in 1501 days
#2 posted 08-25-2018 05:38 PM
I’m not sure, but that looks kinda important. :)
That could have went bad quick, glad it didn’t.
View lew's profile
lew
12931 posts in 4357 days
#3 posted 08-25-2018 09:09 PM
Glad it didn’t take off.
I love my Easy Wood Tools!
