Transporting Plywood in the Rain
Forum topic by MikeDVB posted 08-25-2018 02:31 PM 5709 views 0 times favorited 22 replies Add to Favorites Watch
View MikeDVB's profile
MikeDVB
180 posts in 2342 days
08-25-2018 02:31 PM
I ran a few searches and saw information on rough cut lumber and dimensional lumber but couldn’t find anything specific to plywood.
I’ve been wanting to start a few projects where I need plywood in the shop – for shop fixtures. Clamp holder/organizer, screw organizer, etc. I’m not worried if the wood looks like it got wet – I’m worried about it being damaged. I know that plywood is more stable but I’m not sure what to expect when transporting it in the rain.
I have an F150 but it only has a 5.5’ bed [have a full family, needed the big cab which meant a long bed wasn’t an option] and I do have a tonneau cover that I can use to cover most of the wood. Normally if I was using just the bed I’d leave the gate up, slide the wood in, and then lay the cover down on the wood. I have a 5×8 open trailer that I prefer to use to transport materials but with it raining the truck bed/cover would at least give some cover from the rain.
I could put a tarp over the end of the wood that sticks out but due to the angle – the water will just run down the tarp into the bed and onto the wood. I could lay it flat and leave the gate down and throw a tarp over the end and I think I’d be less likely to get water onto the wood at all.
That said – my boys’ soccer games today were canceled and I have unexpected free time where I can get into the shop and make some of the things I’ve been wanting to make – and the games were canceled due to rain.
I just plan on going to the local box store which is about ~8 minutes from my house so it wouldn’t be a long drive in the rain either way even if I left the wood fully exposed.
I suppose my biggest concern is that once I get home I’d really like to start working with it immediately. I’m wanting to make some french cleats out of 3/4” plywood that I will mount to 1/2” plywood that I will then mount to the wall… Or maybe I’ll mount the 1/2” to the wall and then mount the cleats.
Either way – I’m not worried about the wood not looking great – more about it not being damaged / warped / too wet to work with when I get back. I know that in the past when I’ve gotten 2×4s wet that they’ve generally twisted and warped pretty bad. I’m thinking that due to the nature of plywood I shouldn’t have that issue but I’ve never tried.
Not sure if this link will work but I was hoping to get a couple sheets of this [as well as the 1/2” version].
https://www.menards.com/main/building-materials/panel-products/specialty-panels/hardwood-panels/3-4-x-4-x-8-classic-birch-wood-veneer-core-plywood/1251699/p-1444441906195-c-13334.htm?tid=9041691384408773987&ipos=4
-- Mike
22 replies so far
View Robert's profile
Robert
4640 posts in 2640 days
#1 posted 08-25-2018 02:56 PM
I’ve done it successfully and my truck doesn’t have a cover.
Since you do, just cover the exposed plywood with a tarp put a couple feet up under the covers.
You can either weight it down or attach tarp to a 2×4 and clamp that to the ply.
Put plywood on a couple 2×4 runners allowed you to use clamps..
MikeDVB
#2 posted 08-25-2018 02:57 PM
I ve done it successfully and my truck doesn t have a cover.
- rwe2156
It will still get a little wet taking it out of the store to the truck and while loading it – I assume the little bit it will get wet during this won’t have much impact?
-- Mike
View Rayne's profile
Rayne
1319 posts in 2699 days
#3 posted 08-25-2018 03:06 PM
- rwe2156
It will still get a little wet taking it out of the store to the truck and while loading it – I assume the little bit it will get wet during this won t have much impact?
- MikeDVB
I’d use those carts that holds the ply vertically for the least amount of rain impact. Or if you’re at a big retail home center (HD, Lowes, etc.), they usually have a contractor pick up area with a huge cover, so no chance of rain hitting your supplies. To fully protect your ply, I have considered the option of double tarping the ply: wrap the tarp on one side and secured on the other side, then use another tarp on the opposite side and secure on the initial side so any water that does get in won’t actually hit the plywood. I live in Central FL, so I have to take into consideration when rain will hit as well.
Rick Dennington
7167 posts in 4354 days
#4 posted 08-25-2018 03:21 PM
Why don’t you just wait till it’s not raining to go the plywood….or other wood…? Sounds logical to me…!!
-- " There's a better way.....find it"...... Thomas Edison.
View builtinbkyn's profile
builtinbkyn
3028 posts in 2100 days
#5 posted 08-25-2018 03:30 PM
Load up under the covered area in the “contractor’s/pro” parking area/loading zone. Cover with the appropriately sized tarp of plastic wrap. Leave the tailgate down and tie back the load to the hold downs in the bed. Remove one sheet at a time when you get home, leaving the tarp in place between removal. You’ll get wet and the ply will get some water, but you should be fine. 2×4 runners under the load as rwe2156 suggested above, will go a long way too, for keeping things dry.
-- Bill, Yo!......in Brooklyn & Steel City :)
MikeDVB
#6 posted 08-25-2018 03:33 PM
I don’t think where I’m going has the pro/contractor cover – I’m pretty sure I’ll just be in the parking lot. I can ask them if there is anywhere I can load it beyond the parking lot and will see what they say.
The store that does have that area charges twice as much for lower grade plywood.
-- Mike
View JRsgarage's profile
JRsgarage
410 posts in 1669 days
#7 posted 08-25-2018 03:36 PM
If your project doesn’t require full size, have them cut it to fit underneath you tonneau
-- “Facts don't care about your feelings.” ..., Ben Shapiro
View mtnwalton's profile
mtnwalton
104 posts in 2186 days
#8 posted 08-26-2018 03:22 AM
I usually have plywood ripped and load under roof at contractors entrance. (it helps to have a van)
View Andybb's profile
Andybb
3324 posts in 1763 days
#9 posted 08-26-2018 07:18 PM
- MikeDVB
That won’t hurt it.
-- Andy - Seattle USA
7083 posts in 3653 days
#10 posted 08-26-2018 09:15 PM
Well, if none of the above will work, you can buy a bag specifically made to enclose plywood for transport; the Kerry-All pouch. Actually, it’s not too terribly expensive though the shipping is a pretty good add.
View 000's profile
000
2859 posts in 2059 days
#11 posted 08-26-2018 09:23 PM
Just go buy a Cargo Van,
the few drops that get on it loading/unloading won’t hurt,
and you will be able to lock your tools in the van when you use it for other stuff.
You can sleep in it when you go camping!
Easy peasy (if you got an extra 30 grand laying around) lol
Rayne
#12 posted 08-26-2018 09:56 PM
Why don t you just wait till it s not raining to go the plywood….or other wood…? Sounds logical to me…!!
- Rick Dennington
Sure, if it was that easy to predict the weather. I’ve gone to Rockler on a perfectly clear, blue sky morning. Takes 40 minutes to get there. Shopped for 30 minutes, got my stuff, walked out and it was mostly cloudy with rain on the horizon. I got home, unloaded, and it started to rain within 20 minutes. You can’t always rely on what you see or what the weather channel says. Having a contingency plan is always welcome.
View bigJohninvegas's profile
bigJohninvegas
1063 posts in 2622 days
#13 posted 08-26-2018 10:19 PM
Load up under the covered area in the “contractor s/pro” parking area/loading zone. Cover with the appropriately sized tarp of plastic wrap. Leave the tailgate down and tie back the load to the hold downs in the bed. Remove one sheet at a time when you get home, leaving the tarp in place between removal. You ll get wet and the ply will get some water, but you should be fine. 2×4 runners under the load as rwe2156 suggested above, will go a long way too, for keeping things dry.
- builtinbkyn
2X4 runners and a tarp would be perfect. I am a truck driver that used to haul over the road for a lumber company. The runners will keep the wood out of any water that pools in the bed of your truck.
when you get home I would go ahead and remove the tarp to unload if it is just a sprinkle or light rain. wait a little if its raining hard.
When I would deliver truck loads of lumber, and it was raining at the time of unloading. I would pull back my tarps as needed. to keep the bundles of lumber as dry as I could. And if it was pouring rain, well that was a good time to take a nap. As long as the plywood is not getting soaked, it will be fine. If it does get a little wet, sticker the sheets as you stack them, A day or two they will be dry, and good as new.
-- John
MikeDVB
#14 posted 08-27-2018 12:16 AM
- Rick Dennington
The only reason I had time to work on anything or to pick anything up was because it was raining. All of my normal plans were canceled due to the rain.
I ended up going today while it was dry and picked up 6 sheets of 8’x4’x3/4” and 3 sheets of 8’x4’x1/2”.
-- Mike
Rick Dennington
#15 posted 08-27-2018 01:21 AM
Well…...there you go…..!!!
