Frustrated with Dewalt DW734 dust collection
Forum topic by FrankTuna posted 08-25-2018 01:50 PM 3329 views 0 times favorited 9 replies Add to Favorites Watch
View FrankTuna's profile
FrankTuna
7 posts in 526 days
08-25-2018 01:50 PM
I have a 2 HP Grizzly dust collector rated for 1700 CFM (but I get that’s not what will be measure at the tools). Even when my Dewalt 734 planer is the only tool hooked up with about 6-7 ft of 4” flex hose, I still get chips shooting out of the planer when working with anything more than 6”. Is there anything that might help? Bigger hose? Is it just the nature of this planer?
9 replies so far
View Gene Howe's profile (online now)
Gene Howe
12002 posts in 4040 days
#1 posted 08-25-2018 02:16 PM
Well, mine’s a 735 with a 4’ long, 4” hose connected to a dedicated 1 hp Delta DC and I get chips, too. Dunno if anything cheap and easy will totally eliminate that. I’m about to install a Shelix head. That might help.
View bilyo's profile (online now)
bilyo
962 posts in 1714 days
#2 posted 08-25-2018 02:44 PM
I have a very similar setup except my flex hose is 6”. It collects virtually all the chips with no problem. Assuming your DC is working properly with adequate air flow, I’m thinking that perhaps the passageway for chip ejection inside the planer is partially blocked. Also, are you using the plastic dust chute adapter that came with the planer? Is it secure? I have had problems with the weight of the flex hose pulling the adapter out of alignment partially blocking the dust port. If all of that is OK, I would say that you need a larger hose.
View Rich's profile (online now)
Rich
5157 posts in 1201 days
#3 posted 08-25-2018 03:11 PM
Make certain nothing is inhibiting the flow. The 733 and 734 were prone to clogging up occasionally. The only time my old 733 spit out chips was when it was blocked, or my DC was full.
View mel52's profile
mel52
1213 posts in 876 days
#4 posted 08-25-2018 05:19 PM
I have a 734 hooked up to a dust deputy/16 gal 6 h.p.? Ridgid shop vac., with around 15 feet of hose. The only time I have trouble is when I have a partial plug in my line, which is rarely, or when my bucket gets fuller. I have noticed it might be more frequent when using sappy wood like pine, or if taking to much of a bite causing an excess amount of chips.
-- MEL, Kansas
Gene Howe
#5 posted 08-25-2018 07:56 PM
I didn’t mean to imply that mine makes a habit of throwing chips. But it does occasionally. Thinking about it, it happens when its a larger chip and, maybe too heavy to get sucked up. Those knives are turning towards the front, while the vac attachment is at the back.
View lew's profile
lew
12939 posts in 4367 days
#6 posted 08-25-2018 09:21 PM
I think the 4” hose might be part of the problem. With a 6” hose, my 735 rarely throws chips even with 10”-12” boards
View GrantA's profile
GrantA
2136 posts in 2019 days
#7 posted 08-26-2018 10:28 AM
My 734 did great with a 10ft 4” hose kinked up on the floor, you did remove the 4-2.5” reducer right? And make sure the chute is attached firmly, I either lost the original screw or it doesn’t come with one, I found one though and used it at the bottom of the chute.
View becikeja's profile
becikeja
1045 posts in 3425 days
#8 posted 08-26-2018 10:42 AM
I have a 90 degree elbow connected right on the dust chute that is connected to a 4” hose. The only time I have had a problem is when I had a clog in the line between the blades and the dust chute. Once cleared all was back to normal.
View Redoak49's profile (online now)
Redoak49
4359 posts in 2600 days
#9 posted 08-26-2018 11:53 AM
I have a 735 hooked up with a 4” hose and get no chips. While I get flows of 700 cfm connected to my cabinet saw, I only get 260 cfm hooked to the 735. The hose connection on it appears to be 4” but actually is only 2.5”.
The 1700 cfm referenced about is just baloney and probably only around 700 cfm. The numbers I mentioned are actually measured with a hot wire anemometer with a 5 hp cyclone. I would expect a 2 hp to be significantly less.
