Can I put polyurethane over oil stain or wax
Forum topic by TJ65 posted 08-23-2018 02:38 AM 744 views 0 times favorited 9 replies Add to Favorites Watch
View TJ65's profile
TJ65
1381 posts in 3652 days
08-23-2018 02:38 AM
Hi guys,
Haven’t been on here for ages but thought that you might be able to help.
I am currently working on a walking staff and am up to the finishing stages. I have painted carved areas with acrylic and wanted to know if I can put a natural or coloured OIL or WAX “under” the final coats of polyurethane.
On the instructions on the tin you can use a natural teak oil “AFTER”a coat of polyurethane to give it a natural look.
Any help would be appreciated thanks
-- Theresa, https://www.facebook.com/derrymore/
9 replies so far
View TheFridge's profile
TheFridge
10859 posts in 2088 days
#1 posted 08-23-2018 03:03 AM
Not sure about oil topcoat and acrylic underneath.
Not sure about the oil the poly though I think that’ll be ok.
I am sure you don’t want to wax before poly or it won’t adhere.
View bondogaposis's profile
bondogaposis
5604 posts in 2953 days
#2 posted 08-23-2018 03:11 AM
Don’t put wax down first, poly won’t stick to it.
-- Bondo Gaposis
View bandit571's profile
bandit571
24352 posts in 3285 days
#3 posted 08-23-2018 03:49 AM
Oil stain, wipe off the excess…let dry until you no longer can smell it….then the poly…later you can add wax over the poly…..or, just buff the poly once it is fully dry.
View Joe Lyddon's profile
Joe Lyddon
10859 posts in 4654 days
#4 posted 08-23-2018 04:22 AM
We ALL agree… You DO NOT put anything OVER the WAX… Wax is always the Final top coat, if used.
Oil first and wait until FULLY CURED… and to be safe, wait some more… Then cover with Poly…
... and, if you want, wax on top of the poly!
Bottom line, Wax is always optional.
Once OIL has been applied & is cured,
... then, optionally covered with poly for additional PROTECTION…
... then, optionally covered with a wax for more beauty.
Combo’s that are ALL OK:
Wax all by itself. (you like the Natural colors and poly protection is not needed)
Oil all by itself. (you like the stained / oiled look… poly protection not needed)
Oil, then Poly. (you like the stained / oil but also need poly protection)
Oil, then Poly, then Wax. (you like the stained / oil, want poly protection, and the beauty of wax)
Looking forward to seeing your Final project! :)
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: https://www.ncwoodworker.net/forums/index.php
View Andrek's profile
Andrek
507 posts in 2512 days
#5 posted 08-23-2018 10:17 AM
Hi there.
I never use anything over wax,( on furniture wax attracts dust.) as for poly over oil , wait at least 24 hours. ( that is with mild temperature outside ) otherwise wait a bit more.
Have a nice day in the shop.
-- andrek
View EarlS's profile
EarlS
3409 posts in 2950 days
#6 posted 08-23-2018 11:22 AM
I use Watco (Danish oil) quite a bit and I think the directions call for 48-72 hours minimum cure, then a light sand with 320 or higher, then apply the poly. Have you thought about using Arm-R-Seal? It is a poly/oil combo that wipes on and it finishes up great. Wax and buff after it dries.
View OSU55's profile
OSU55
2498 posts in 2591 days
#7 posted 08-23-2018 12:25 PM
Teak oil or anything else should NOT be put on after the poly – it wont do anything but come off. Test the poly over acrylic paint on scrap – not sure about it and thats nice art work you dont want to mess up. If the poly is ok, you can mix the liquid part of any oil based stain with the poly (doesnt take much, use a dark color) to enhance the natural look. Other products arent needed.
View AAL's profile
AAL
82 posts in 2028 days
#8 posted 08-23-2018 12:40 PM
That is a nice looking staff. Well done indeed!
If the intent is ever to use it, I would certainly protect at least the handle portion with several coats of polyurethane to protect against eventual wear.
-- "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
View AAL's profile
AAL
#9 posted 08-23-2018 12:41 PM
If the intent is ever to use it, and as you indicated, I would certainly protect at least the handle portion with several coats of polyurethane to protect against eventual wear.
