Furniture Finish Error?
Forum topic by jimleigh1313 posted 08-13-2018 04:07 PM 465 views 0 times favorited 5 replies Add to Favorites Watch
View jimleigh1313's profile
jimleigh1313
65 posts in 3017 days
08-13-2018 04:07 PM
Good morning.
Just had built-in media cabinets installed in my living room by a furniture builder. He stained and applied polyurethane all in one day on the horizontal “desk” that was part of the build. Two days later, and the finish is still “tacky”/sticky, and the stain rubbed off onto my pants when I leaned against it.
Question is, I am pretty sure he didn’t let the stain dry prior to applying the poly. However, will I be good if I just give it additional time to dry? Seems like if not then moisture may be trapped? Also, should I put any other finish over top just to make sure it is all sealed off? Thanks a ton!
5 replies so far
View EarlS's profile
EarlS
3431 posts in 2956 days
#1 posted 08-13-2018 04:58 PM
First off, I’d withhold paying him. Then I’d ask him to come back over and show him the problems. I’d say he needs to strip it off and start over. Stain needs time to dry before applying a finish over it. Otherwise the “solvent” in the satin doesn’t have any way to evaporate and you get a sticky mess because the stain solvent is interfering with the curing process of the finish.
If he used an “all-in-one” stain finish then it might need more cure time or he put too much on. One coat doesn’t seem like enough for a desk.
View Bill White's profile
Bill White
5242 posts in 4568 days
#2 posted 08-13-2018 05:50 PM
A “call back” is in order for sure.
-- [email protected]
jimleigh1313
#3 posted 08-13-2018 06:54 PM
Without going into too much detail, let’s just say extenuating circumstances have warranted a “call back” as out of the question. Are there any options I can work with to correct the issue?
EarlS
#4 posted 08-13-2018 07:02 PM
Jim – I PM’d you with some ideas.
View mahdee's profile
mahdee
4291 posts in 2376 days
#5 posted 08-13-2018 08:29 PM
Get some paint stripper and take everything off and start over.
-- earthartandfoods.com
