Thought I bought an older Delta DC, but it's a newer one. Help on upgrades!
Forum topic by T_C posted 08-08-2018 05:41 PM 1127 views 0 times favorited 3 replies Add to Favorites Watch
View T_C's profile
T_C
2 posts in 528 days
08-08-2018 05:41 PM
Topic tags/keywords: delta 50-850 dust collector
Hi all,
I’ve been in the market for a new DC, I currently have a Jet 650, it’s just not quite enough CFM for my shop. I saw an ad for Delta 50-850 dust collector locally on FaceBook Market and thought I’d take the plunge to upgrade. I talked them into $150 and headed over after work for a look. I did a little research in the meantime and everyone seemed to like the model.
Upon arrival I did an inspection and thought the Delta was in good shape, no rust, no dent’s dings. He had both top and bottom cloth bags (not plastic) but didn’t know the micron rating. Looked at the impeller blades, all nice, no imapct marks or wear/tear from sucking up cat litter, stuck my hand inside and felt for the infamous baffle. Nothing. Hmm.. cool. Must be one of the original series. No Mod 1 or 2 on the model number sticker.
I read about how they changed the size of the impeller over the years. 12”, 11.2” 11”. They also increased the restrictor plate to keep people from burning up motors. I’m thinking there is no restriction plate, this must be first generation! Yay! Score!
Got it home and took off the dual 4” Y adapter and the examined the intake The opening looked a little big. Measured it and it’s 7” across. Strange, never heard any mention of that on the write-ups. A 7” intake and a 6” output.
Then I look at the impeller, small? Measured it and I get 10”.
Crud!!! This is not good.
I’m guessing it’s the last generation, instead of putting in the restriction plate (that everyone was removing) they just down down sized the impeller? Make sense?
Any recommendations on a replacement impeller? I measured the housing and it seemed about an inch and quarter between the blades and the closest point on the housing.
I plan on putting this unit on top of a cyclone, Super dust deputy, building a new system all around. I can neck down the 7” intake to 6” to fit the cyclone.
Suggestions? Recommendations?
I’m also looking for pleated filters to replace the bags. Oneida? Penn? Wyn? So many choices. I know its more efficent but I don’t want to vent outside.
3 replies so far
View Robert's profile
Robert
3598 posts in 2082 days
#1 posted 08-13-2018 02:29 PM
Yes you can. I would suggest an adapter with a short segment of 6” flex to the collection lid. This will make removing and dumping easy.
If you can vent outside it will help greatly help efficiency this is a borderline blower you need to do what you can to help eliminate back pressure.
Be sure to run 6” ducts.
View GR8HUNTER's profile
GR8HUNTER
6797 posts in 1314 days
#2 posted 08-13-2018 02:41 PM
sounds like a GREAT DEAL :<))
View T_C's profile
T_C
2 posts in 528 days
#3 posted 08-13-2018 03:45 PM
Thanks folks.
Any suggestions for a replacement impeller? I’m guessing the 10” is a little undersized for what the motor can really do.
Anyone use the Continental 280? It’s semi caged design but since I’m on top of a cyclone I’m hoping I have pretty clean air and won’t throw it out of balance.
