I am looking for Delta 34-802 handwheel
Forum topic by LucWinters posted 08-08-2018 05:40 PM 967 views 0 times favorited 16 replies Add to Favorites Watch
View LucWinters's profile
LucWinters
8 posts in 534 days
08-08-2018 05:40 PM
Topic tags/keywords: handwheel delta unisaw 34-802
One of my handwheels got damaged (broke in pieces) transporting my Delta unisaw to my new workshed.
I am looking now for couple of months to find a replacement, but cannot find it.
It is the cast aluminium handwheel with the delta shape in the middle.
If anyone has one for sale, or knows where i can find one i would be very happy.
Regards fromb a happy Delta unisaw user from the Netherlands.
Picture of the remaining one:
16 replies so far
View therealSteveN's profile
therealSteveN
4648 posts in 1182 days
#1 posted 08-09-2018 06:07 PM
Something like this?
In reality I don’t think the “Delta” is that important. I would make sure of the center hole size, and call Grizzly to see how much. Probably S&H will be your devil.
Grizzly
Grizzly handwheels)
-- Think safe, be safe
View TheFridge's profile
TheFridge
10859 posts in 2094 days
#2 posted 08-09-2018 06:11 PM
ID of the bore and the wheel dia is what matters. Should be pretty standard.
Looks like you’re missing the locking knob as well.
LucWinters
8 posts in 534 days
#3 posted 08-09-2018 08:27 PM
Thanks for your replies,
I would like to have the delta shape to keep it original. (the saw is kind of retauration project)
A different shaped handwheel i can find also in the Netherlands.
For the s&h i have until end october a solution as a collegue is on a training trip to San Diago and is willing to take items with him on his way back.
The locking knobs are still there, i took it of to get a clear picture of the handwheel.
Measurement of the middle hole 19mm =0,74inch? (Not sure if i translate thia right)
Diameter of the handwheel is 7.5 in.
MrUnix
7597 posts in 2806 days
#4 posted 08-09-2018 08:56 PM
I don’t think that is the proper handwheel for your Unisaw. AFAIK, the Unisaw never had cast aluminum handwheels – they were made of steel. They also did not have the triangle middle section like the ones you have, which I believe I remember seeing on one of their contractor type saws. Did you purchase this saw new or know of it’s history? If you look up the parts diagram for your machine (like this one at ereplacementparts.com), you will see what the standard handwheel looks like. If you really want to keep the ones you have, then your best bet would probably trying to find one on e-bay. Otherwise, It would probably be easier to just swap both of them out with the correct handles, which can be found quite easily all over the place.
LucWinters
8 posts in 534 days
#5 posted 08-09-2018 09:48 PM
Thanks Brad,
But..If you look at the type one, (that is the one i have, looking at the stand with dust door)
There are delta shaped handwheels.
https://www.ereplacementparts.com/delta-34802-type-1034-tilting-arbor-unisaw-parts-c-3275_3334_14084.html
MrUnix
#6 posted 08-09-2018 11:51 PM
Interesting… I guess that was one of the cost-cutting measures taken on some of the newer machines. The good news is that any handwheel from a Unisaw should fit, regardless of year, so you have a wide range of choices. I did find one like yours over at the OWWM site in the BOYD section for $45 delivered, but it’s been out there for a while so I’m not sure if it’s still available:
(http://www.owwm.org/viewtopic.php?f=4&t=168599&p=1147278)
You need to be a member to access the BOYD section and send messages, so I went ahead and send a query to him to see if it was still available. Hopefully will have an answer soon on that one.
There are also a few pairs of the more standard steel ones for about the same price or just slightly higher since there are two instead of just one.
LucWinters
8 posts in 534 days
#7 posted 08-11-2018 08:45 AM
Thanks Brad!
Hope it is still available, i have to say i like the delta shape, it fits a delta machine. (Even if it is done for cost reducing)
I keep on looking on ebay, and other places.
Regards,
Luc
View Rayne's profile
Rayne
1298 posts in 2147 days
#8 posted 08-11-2018 11:32 AM
Would this work? I didn’t check any specifics but it does list the TS it is compatible with and is a Delta brand.
http://www.mikestools.com/1346719-Delta-Handwheel.aspx
LucWinters
8 posts in 534 days
#9 posted 08-11-2018 11:58 AM
Thanks for your suggestion Rayne,
I found similar on ereplacement, but there it was discribed as 5in diameter.
Here i cant find a good discription, will send them a mail.
Regards,
Luc
View MrRon's profile
MrRon
5811 posts in 3851 days
#10 posted 08-11-2018 05:16 PM
- LucWinters
Handwheels are expensive and especially with shipping. By the picture, it looks like it would be easy to repair the broken one. Just have a plate made up, 1/4” thick x 7.5” diameter and have a boss welded to the plate, bored out to 19mm and attached to the back of the broken handwheel with screws. You could cut the plate into a 3 arm shape to mimic the original.
MrRon
#11 posted 08-11-2018 05:25 PM
- LucWinters
Handwheels are expensive and especially with shipping. By the picture, it looks like it would be easy to repair the broken one. Just have a plate made up, 1/4” thick x 7.5” diameter and have a boss welded to the plate, bored out to 19mm and attached to the back of the broken handwheel with screws. You could cut the plate into a 3 arm shape to mimic the original. Since this is a Delta, I’m sure the bore is 3/4”, not 19mm. 19mm is .748”; 3/4” is .750”. Reading your caliper, I can see a reading of .751” and that would be the correct size for a 3/4” (.750) bore.
LucWinters
8 posts in 534 days
#12 posted 08-11-2018 05:36 PM
MrRon,
Thanks for your info on the measurements, i always hassle with the conversion to inch.
I sometimes use a app on my phone, but this gives me .748 but i dont know the 3/4, 5/16, have to read on that a bit.
For now i repaired the handwheel by bolting a strip of metal with a handle to the adapter, works fine.
But still i like it to be replaced with a new (used)one.
I like to keep my tools in good shape.
Reg.
Luc
View Shaun Ragland's profile
Shaun Ragland
14 posts in 964 days
#13 posted 08-13-2018 05:38 AM
Luc,
Just multiply inches by 25.4 and that is your metric equivalent !
For metric to inches devide by 25.4 and that is your inches equivalent !
Good luck and happy Woodworking
Shaun Ragland
-- Shaun Ragland
TheFridge
#14 posted 08-13-2018 05:41 AM
Google has a conversion calculator I use a lot
LucWinters
8 posts in 534 days
#15 posted 08-15-2018 09:01 AM
Thanks guy’s
I know the conversions.
Fractions makes it difficult.
Reg.
Luc
