3 inch wide boards for a tabletop
Forum topic by Gibsonman posted 08-07-2018 06:21 PM 546 views 0 times favorited 8 replies Add to Favorites Watch
View Gibsonman's profile
Gibsonman
50 posts in 2197 days
08-07-2018 06:21 PM
I’m getting started on a farm table for our house and have ran into a snag. I have 6n wide 8/4 cherry that i plan to use for the top. I was going to run them through my planner(since i don’t have a jointer) to get the edges ready for glueing. The problem is my planner does want to raise above 3 1/2in. Would the table look strange if i ripped the boards to 3in and then made the top using them? I have been looking for examples but haven’t found any that appear to have narrower boards int he top. Any ideas would be helpful. Thanks
8 replies so far
View jmartel's profile
jmartel
8698 posts in 2760 days
#1 posted 08-07-2018 06:26 PM
Why not pick up a handplane? Should be able to get one fairly cheap. #6 or #7 would work fine.Then you can joint any width board.
View ArtMann's profile
ArtMann
1462 posts in 1426 days
#2 posted 08-07-2018 06:49 PM
P-l-a-n-e-r. not p-l-a-n-n-e-r. If you were planning to use a table saw to rip the boards to width, why not buy a glue line rip blade and use it to straighten and flatten your edges before gluing? I do glue ups all the time using edges prepared that way and the result is the same whether they were jointed or ripped.
The more pieces you use to glue up a large surface, the more chance you will have of the edges not matching up exactly. You will need to plan for that problem no matter how you proceed.
View Woodknack's profile (online now)
Woodknack
13025 posts in 2990 days
#3 posted 08-07-2018 07:54 PM
... If you were planning to use a table saw to rip the boards to width, why not buy a glue line rip blade and use it to straighten and flatten your edges before gluing? I do glue ups all the time using edges prepared that way and the result is the same whether they were jointed or ripped.
- ArtMann
+1
I don’t own a jointer and use my TS to joint edges and I’m happy to show closeups of any of my joinery/glue lines.
View Aj2's profile
Aj2
2651 posts in 2408 days
#4 posted 08-07-2018 08:00 PM
Have you read the thread edge jointing on the tablesaw. Apparently you don’t need a jointer.
Don’t rip them smaller it might make thing worse.
-- Aj
Gibsonman
#5 posted 08-07-2018 08:45 PM
Thanks for the help guys. I didn’t think about jointing with a table saw.
I do have hand planes it just seems like i mess the edge up when i try to joint them. On this length of wood(7 foot) i figured i would mess the edge up more then already they are.
View Aj2's profile
Aj2
#6 posted 08-07-2018 10:41 PM
Don’t feel bad hand planing the edge flat square and straight is not that easy.
-- Aj
jmartel
#7 posted 08-07-2018 10:56 PM
You could always make a TS straight line ripping jig. Or use an edge guide and a circular saw (unless you have a track saw, in which case, use that). Both are free/cheap.
And jointing by hand is easier if you plane both edges of the mating pieces at the same time, and check with a long level. Fold them like a book so the top face is out on both boards. Once you get them flat/flush, and check that there’s no bumps with the straight edge, you should be open it up like a book and have it mate up.
View oldnovice's profile
oldnovice
7517 posts in 3977 days
#8 posted 08-08-2018 06:51 PM
+1 for table saw jointing!
