Build a bowl from a board
Forum topic by Ldc posted 08-07-2018 06:06 PM 324 views 0 times favorited 1 reply Add to Favorites Watch
View Ldc's profile
Ldc
14 posts in 1656 days
08-07-2018 06:06 PM
Has anyone built a bowl from a board using compound angles ( no turning). If so could you share any insight.
1 reply so far
View OSU55's profile
OSU55
2507 posts in 2598 days
#1 posted 08-07-2018 06:22 PM
I made a few. I did turn them after glueing but up to that point its the same process. Used a circle cutting jig on a bandsaw and tilted the table. Glued and clamped the saw kerf from the blade. Used titebond III. Lot of to sand and finish w/o turning but can be done. I may be able to get the dia and angles I used if needed. If you havent look up Ringmaster lathe. Should be info for angles and dia.
