Beech fine line plywood
Forum topic by Spwhite posted 08-02-2018 12:00 PM 983 views 0 times favorited 8 replies Add to Favorites Watch
View Spwhite's profile
Spwhite
2 posts in 544 days
08-02-2018 12:00 PM
Hello all, I was in Lowes the other day and came across some plywood labeled beech fine line, it is edge glued so that the layers show on the top. My wife has been after me to make a cutti g board for her. My question is, the glue they used to mami he it together, would it be food safe to use as a cutting board or should I just glue up my own. I looked an couldn’t find any info on it .
Thanks
8 replies so far
View LittleShaver's profile
LittleShaver
610 posts in 1230 days
#1 posted 08-02-2018 12:13 PM
When in doubt, DON”T DO IT.
Make your own, it will mean more in the long run.
-- Sawdust Maker
View bondogaposis's profile
bondogaposis
5610 posts in 2962 days
#2 posted 08-02-2018 12:20 PM
You can be pretty sure that it is not food safe if it is not intended for that use.
-- Bondo Gaposis
View JCamp's profile
JCamp
1040 posts in 1161 days
#3 posted 08-02-2018 01:13 PM
Doubt it. No bigger than a cutting board is you can probably make your own
-- Whatsoever thy hand findeth to do, do it with all thy might
View waho6o9's profile
waho6o9
8812 posts in 3188 days
#4 posted 08-02-2018 02:08 PM
Definitely make your own cutting board.
View DS's profile
DS
3360 posts in 3031 days
#5 posted 08-02-2018 02:17 PM
I had to look…
https://www.lowes.com/pd/Actual-0-99-in-x-23-98-in-x-4-ft-Beech-Board/1000427561
I have no strong opinion about it, but, I probably wouldn’t use this for a cutting board.
View ScottM's profile
ScottM
747 posts in 2757 days
#6 posted 08-02-2018 02:18 PM
Sorry for digressing, but I’m actually more interested in the wood itself. The Lowes closest to me only sells that “Blondewood” crap. Still not really sure what that is….
View CaptainKlutz's profile (online now)
CaptainKlutz
2271 posts in 2105 days
#7 posted 08-02-2018 05:03 PM
Have never seen it before @ lowes? Is not stocked locally, so guess I never will see it. :(
Edge glued beech makes nice cutting board. Just a little softer than hard maple, and is easy on knife edges.
If this really is 1 inch thick solid beech, edge glued; then it could safely be used to make thin cutting boards.
If it is ends up being beech veneer over composite wood core, then do not use it.
Cheers!
Spwhite
2 posts in 544 days
#8 posted 08-02-2018 08:20 PM
Thank yall for the reply looms like I’ll be doing some glue ups
