Fan for my Garage Shop in Texas
Forum topic by Ardubya posted 08-01-2018 01:48 PM 1061 views 0 times favorited 15 replies Add to Favorites Watch
View Ardubya's profile
Ardubya
65 posts in 1746 days
08-01-2018 01:48 PM
Hey gang – I live in southeast Texas and you can imagine what summers are like here and how long it stays hot. I need to get a fan for my detached 2-bay garage shop. I’d like to move as much air as possible with relatively low noise. My first thought was a pedestal fan but now I’m considering wall or ceiling mount to save floor space, but there is something to be said about the ability to situate the fan wherever you want it.
Typical places like Northern Tool and Harbor Freight have decent options. Recently I saw a Vornado product that claims to move a lot of air, and it can double as wall mount or floor stand. I hear Vornado products are good.
Any recommendations? Thanks!
15 replies so far
View GR8HUNTER's profile
GR8HUNTER
6797 posts in 1314 days
#1 posted 08-01-2018 01:57 PM
https://www.globalindustrial.com/g/hvac/fans/ceiling-beam/oscillating-ceiling-mount-industrial-fans :<))
View JCamp's profile
JCamp
1036 posts in 1152 days
#2 posted 08-01-2018 01:57 PM
I’ve never done it but I’ve thought about for myself using a box fan and putting a HVAC filter on the intake side of it. It would circulate air and clean it as well
-- Whatsoever thy hand findeth to do, do it with all thy might
View Bill_Steele's profile
Bill_Steele
630 posts in 2333 days
#3 posted 08-01-2018 02:36 PM
I’m curious how well those evaporative coolers (a.k.a. swamp coolers) work? I wonder if that might be something that would help you? It may be more than you want to get into, but I found this interesting video where a guy built something for his greenhouse. He took the temp from 99 to 86—but the humidity did go up—which might be a concern for a wood shop.
Ardubya
#4 posted 08-01-2018 02:43 PM
Yes, I will be avoiding anything with a moisture element. Thanks anyway.
View bandit571's profile
bandit571
24349 posts in 3285 days
#5 posted 08-01-2018 02:44 PM
Used to be, they would mount a “turbine” on the peaks of roofs….Hot air rising up out through them….any breeze coming along would give the blades a spin…drawing even more hot air out ( outlawed in Washington DC?) to cool the insides of the barn/shed/shop. You can add a fan under it, to help draw the heat.
View Jeff's profile
Jeff
515 posts in 3796 days
#6 posted 08-01-2018 02:47 PM
I live in NC and the heat and humidity in my two car garage is sometimes unbearable. The most effective thing I did was to insulate my garage door. This knocked ten degrees off the inside. However, it’s not always the solution. I’ve tried several fans but the moving air always seems to get in the way. Either blowing my plans all over the place or sawdust where I don’t want it. Right now I have a small floor mounted fan. But when it gets too hot I just give up and work another day.
View bilyo's profile
bilyo
959 posts in 1704 days
#7 posted 08-01-2018 03:12 PM
IMO, the only way you are going to make your garage comfortable for woodworking is to insulate it and install an AC unit. With a fan only, you will be doing nothing but moving the hot humid air around and it won’t help much. Fans work best in drier climates where the moving air will evaporate your perspiration and make you feel cool. In high humidity, they are much less effective. The same for swamp coolers. They cool the air by evaporating water. If the air is already saturated, they don’t work. I’m in southern Alabama and I cannot work in my shop in mid summer with fan only. I’m sure your situation is equal to if not worse than mine.
View patrickhoelzel's profile
patrickhoelzel
1 post in 558 days
#8 posted 08-01-2018 03:37 PM
I have what started as a pedestal Lasko fan. It moves some serious air and makes my Texas garage bearable in the summer, but the pedestal takes up way too much floor space, and it was always in the way.
There was not a wall bracket available for it, so I made my own. It’s overkill, but that tends to be my style.
I have a tandem 3-car garage. I mounted the fan to cover the main, front 2-car portion and it does well with that. It is in the middle front of the space so it covers well. I plan to add a second wall mounted fan in the ‘back’ third car area as there is no air movement back there.
Answering your question, the bigger fans will absolutely improve the comfort in your space. Skip a pedestal style as it will rob too much floor space. If you have the ability to run two, mount on on each side of the garage for full, constant coverage.
View DBDesigns's profile
DBDesigns
232 posts in 599 days
#9 posted 08-01-2018 03:40 PM
If you have a window, I would suggest mounting a fan in it. That way it can double as an exhaust fan and as an airborne dust cleaner.
I am in The ATL and it gets hot here. My shop has AC and I’m not afraid to use it.
-- I remember when Grateful wasn't Dead
View BroncoBrian's profile
BroncoBrian
875 posts in 2560 days
#10 posted 08-01-2018 03:48 PM
My first suggestion is to load up your F-150 (you know you have one) with your tools and get out of SE Texas. The only place worse than where you are is SW Lousiana.
If that does not work, get a BAF and you will move air while keeping your flat top trimmed.
But really, a good mounted fan with a dehumidifier is a decent option unless you can install a mini-split. I would run a dehumidifier piped out a wall either way.
-- A severed foot is the ultimate stocking stuffer.
View Mike_D_S's profile
Mike_D_S
601 posts in 2816 days
#11 posted 08-02-2018 03:31 AM
I’m in houston and I just use a floor mounted fan. The trick for me is to put the fan just outside the garage blowing in on me.
It’s not scientific proof, but it just feels cooler blowing air in than blowing air from the back of the garage out towards me.
Mike
-- No honey, that's not new, I've had that forever......
View builtinbkyn's profile
builtinbkyn
2999 posts in 1542 days
#12 posted 08-02-2018 03:43 AM
They have these on sale at the big orange store. Saw them today. You might have to tie things down though.
Man I practically live in the darn store these days :(
-- Bill, Yo!......in Brooklyn & Steel City :)
View Richard Lee's profile
Richard Lee
260 posts in 1377 days
#13 posted 08-02-2018 01:24 PM
View Bill White's profile
Bill White
5242 posts in 4562 days
#14 posted 08-02-2018 01:43 PM
Have you thought about plain old ceiling fans? I have 2 in my 20×20 shop, and they do move some air. 52” multi-speed from Lowe’s.
My shop is fully insulated. Ceiling, walls, steel doors, and dbl. pane windows. Money well spent. Never (yet) gets above 85, and N.E. MS it gets pretty darned warm.
-- [email protected]
View edapp's profile
edapp
330 posts in 2031 days
#15 posted 08-02-2018 03:11 PM
Harbor freight is your friend. I purchased a large pedestal fan (36-42” or so?) from them a few months back for ~$90 and it was well worth it. Use it in my shop, use it to workout in the garage. It moves a TON of air…
