Tear out
« back to Joinery forum
Forum topic by hjt posted 07-31-2018 03:26 AM 893 views 0 times favorited 14 replies Add to Favorites Watch
View hjt's profile
hjt
904 posts in 3741 days
07-31-2018 03:26 AM
Topic tags/keywords: jointer tear out
I decided to use my jointer for the first time in years. I was not happy when it tour out the bottom end. What is the best way to prevent this??
-- Harold
14 replies so far
View Aj2's profile
Aj2
2648 posts in 2401 days
#1 posted 07-31-2018 04:01 AM
Well it looks like you were passing the end grain of that board over the knifes. And a piece split off the end just like splitting firewood.
If you absolutely need to joint boards on their ends chamfer the trailing edge.
-- Aj
View John Smith's profile
John Smith
2131 posts in 766 days
#2 posted 07-31-2018 12:01 PM
X2 with AJ
-- I am a painter. That's what I do. I paint things --
View waho6o9's profile
waho6o9
8812 posts in 3180 days
#3 posted 07-31-2018 12:21 PM
Good idea on the chamfer, never heard of that, thanks AJ.
View 000's profile
000
2859 posts in 1502 days
#4 posted 07-31-2018 01:32 PM
X4
View bondogaposis's profile
bondogaposis
5605 posts in 2954 days
#5 posted 07-31-2018 02:23 PM
A jointer is not really designed to joint end grain. There are lots better ways to square up the end of a board.
-- Bondo Gaposis
View AAL's profile
AAL
82 posts in 2030 days
#6 posted 07-31-2018 02:41 PM
Also, you could tightly apply tape along the end edge to be planed & have it wrap tightly around the end of the board. Combine this with light cuts & you should be good to go. You could also tape another (sacrificial) piece of wood to the edge of the board on the exit side of the cut.
-- "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
View hjt's profile
hjt
#7 posted 07-31-2018 05:21 PM
I’m confused.
Bondo – are you referring to the direction of the grain as I ran the board? The grain is running vertical to the table
AAL – I ended up using a push stick as a sacrificial board. that worked but not the easiest thing to do on that jointer.
AJ what do you mean – If you absolutely need to joint boards on their ends chamfer the trailing edge.
-- Harold
View johnstoneb's profile
johnstoneb
3131 posts in 2776 days
#8 posted 07-31-2018 05:41 PM
Yes you were jointing end grain. To joint end grain under power or with hand planes you need to chamfer (cut a slight angle) on the edge. Using a push stick as a sacrificial board sound dangerous. A chmferon the trailing edgekeeps the last bit of wood away from the cutters and prevent the chipping.
-- Bruce, Boise, ID
View Aj2's profile
Aj2
#9 posted 07-31-2018 05:52 PM
Can’t think of a reason to joint the end grain of solid wood. But if you like doing it that’s cool with me
I have straightened out edges of plywood on my jointer,at the cost of nicking the knives badly.
-- Aj
View Jack Lewis's profile
Jack Lewis
571 posts in 1681 days
#10 posted 07-31-2018 06:35 PM
Take a 4-6” cut then reverse ends and do a complete. Takes a little longer but that will releive the end grain that splits out.
-- "PLUMBER'S BUTT! Get over it, everybody has one"
View TheFridge's profile
TheFridge
10859 posts in 2089 days
#11 posted 07-31-2018 07:37 PM
I just crosscut on a table saw and block plane it. End grain in jointer sounds scaryish.
View BroncoBrian's profile
BroncoBrian
875 posts in 2562 days
#12 posted 07-31-2018 07:50 PM
- TheFridge
+1 – end grain should not go on a jointer. Also, make sure your knives are sharp, that would help a lot. But for that edge, crosscut is the way to go. You joint a face, then an edge. Plane the second face, cust the second edge. After those are complete, crosscut the two ends (end grain).
-- A severed foot is the ultimate stocking stuffer.
View enazle's profile
enazle
66 posts in 611 days
#13 posted 08-13-2018 04:33 AM
Mr. Lewis is sharing the proper way to joint end grain. Joint the trailing edge first a couple inches, then spin the board 180 and joint the leading edge until you reach where you jointed the trailing edge and lift the board before you reach the end. You might hit it with a sanding block to true it up.
TheFridge
#14 posted 08-13-2018 05:44 AM
Not disputing that. It does sound like a good way to tear knives up quickly.
