Additional tips for HF hvlp spray gun
Forum topic by DW833 posted 07-30-2018 10:17 PM 731 views 0 times favorited 7 replies Add to Favorites Watch
View DW833's profile
DW833
220 posts in 2491 days
07-30-2018 10:17 PM
Topic tags/keywords: hvlp spray gun harbor freight tips
I’m using the HF hvlp spray gun that comes with a 1.4 tip. Contacted HF and they don’t sell other tips.
HF recommended to use graco tips because they are compatible. I can’t find a source for the tips. All I see for graco are airless tips. Has anyone purchased or used the graco tips?
7 replies so far
View CARSandCustoms's profile
CARSandCustoms
28 posts in 548 days
#1 posted 07-30-2018 11:19 PM
Which model?
DW833
#2 posted 07-31-2018 01:20 AM
Oops. Guess I should have mentioned that. The purple one. Part number 47016.
CARSandCustoms
#3 posted 07-31-2018 01:54 AM
HF compares it to the Kobalt from Lowes and after reading some reviews on that gun, Lowes customers have the same complaint.
What are you trying to spray?
I use to paint cars for a living and have had many guns over the years. I always bought guns that were sized for what I was spraying. Yes, most automotive guns come with a range of tips around 1.2-1.5 but from my limited experience spraying wood finishes, I needed my 2.2 tip primer gun. Urethane clear coat on a car is way thinner than Poly’s used to protect wood.
A quick search found a large tip gun for <$40
https://www.amazon.com/TCP-Global-Professional-Primer-metal-Regulator/dp/B001NOU92G
CARSandCustoms
#4 posted 07-31-2018 06:26 PM
Or, if you’re brave, you could very, very carefully drill the tip out. I’ve heard of it being done but I have never tried it myself.
Really depends on what you are spraying.
DW833
#5 posted 08-01-2018 04:12 PM
Thanks for the feedback. Will continue with what and I have and continue to search for tips. If it doesn’t work out, I’ll have to move to a different gun.
View Bill White's profile
Bill White
5242 posts in 4568 days
#6 posted 08-01-2018 07:27 PM
Have you contacted HF tech services? They’ve got more savvy than the folks at the stores.
-- [email protected]
DW833
#7 posted 08-02-2018 12:49 AM
Yes. They recommended the graco tips. I can’t find them anywhere.
