Source for Maple Base Molding?
Forum topic by jasoncarpentry posted 07-30-2018 06:29 PM 594 views 0 times favorited 7 replies Add to Favorites Watch
View jasoncarpentry's profile
jasoncarpentry
149 posts in 3740 days
07-30-2018 06:29 PM
Topic tags/keywords: base molding maple
I’ve been asked to make several maple bases for displays of sculpted figures. These will be ~1” thick, and squares ranging from 5” x 5” to 9” x 9”. My customer wants these to have base moldings w/ various edge profiles. Where can I buy this molding material? I can’t find it on the web sites for Home Depot, Woodcraft, Highland Hardware, or Rockler.
Again, it has to be solid maple, since I’ll be putting a clear finish on it and would like it to match the bases.
-- Jim in Tennessee
7 replies so far
View John Smith's profile
John Smith
2926 posts in 1248 days
#1 posted 07-30-2018 06:45 PM
why can’t you use router bits or the shaper and make your own ??
do you have any sketches or drawing to help?
any end profiles that you can draw ?
-- there is no educational alternative to having a front row seat in the School of Hard Knocks. --
jasoncarpentry
#2 posted 07-30-2018 07:04 PM
Excellent suggestion, John! I’m considering this, but I’m still intimidated by routers, especially on maple, which is very hard on bits.
-- Jim in Tennessee
View Redoak49's profile
Redoak49
5248 posts in 3074 days
#3 posted 07-30-2018 07:14 PM
Perhaps, you could find someone to help you rout them. Pretty simple on a router table. Maple is easy to rout.
View waho6o9's profile
waho6o9
9019 posts in 3662 days
#4 posted 07-30-2018 07:31 PM
https://www.bairdbrothers.com/Hard-Maple-C12.aspx
5.5” ^
Maybe use Moulding in your search?
HTH
John Smith
#5 posted 07-30-2018 08:57 PM
you can ease the intimidation factor by taking your board, rout the edge
that you like, then cut that part off on the table saw.
when attached to your 9×9 base like with the skirt fashion, it really gives a nice look.
only takes a couple of good carbide bits cutting at different depths
and/or in combination with other bits to make some very unique profile designs.
maple is not as hard on carbide bits as you think . . . .
and best of all – they will all match the projects you are making !!!!
when you start buying wood parts from Tom, Dick and Jane, there is
no telling what you will end up with = time and money wasted.
and if you are making money on this project, you really should work
with the highest quality tools that you can afford. hence: new bits.
do you have a wood lathe ??? you could also make some round ones too !
View Bill Berklich's profile
Bill Berklich
1179 posts in 1474 days
#6 posted 07-31-2018 12:06 PM
+1 on the router method if you have a table. If you don’t mind a skip into Knoxville US Architectural Millwork does great custom work.
-- Bill - Rochester MI
View jonah's profile
jonah
2136 posts in 4384 days
#7 posted 07-31-2018 01:38 PM
Any good millwork supplier will make their own mouldings out of whatever kind of wood you want. It won’t be particularly cheap compared to an off-the-shelf product at a big box, but it’s not ridiculously expensive either. They’ll have a bunch of stock profiles that they always have the cutters for, and getting a batch run off with those will be the most economical option outside of doing it yourself.
