Pre-Jet 5HP Table Saw
Forum topic by Th961605 posted 07-30-2018 06:04 PM 781 views 0 times favorited 2 replies Add to Favorites Watch
View Th961605's profile
Th961605
12 posts in 2244 days
07-30-2018 06:04 PM
Topic tags/keywords: table saw kuang yung belts
I just picked up a beast of a table saw that had a cracked pulley mount. Luckily the piece broke cleanly, and was cast steel rather than iron, so welding went off without a hitch. The company is Kuang Yung, and I know that this saw is essentially the same model that Jet made from 1986. The saw didn’t come with belts, so I’m trying to find some without ordering custom. There
is so little on this saw online that it’s actually pretty unbelievable. I’ve included pictures of the model number, and the saw is a 5HP 3 phase. I currently run a unisaw, but I’m considering mounting a feeder on this to power through some of my standard widths. The top is in excellent shape aside from some fairly beefy surface rust. I did receive new bearings, as well as the original fence and an extension wing. The mag starter is also new. Curious if anyone out there has ever owned one of these, or where a good place to order parts is. Thanks!
http://s1249.photobucket.com/user/th961605/media/IMG-5791zpscaybpkr5.jpg.html
http://s1249.photobucket.com/user/th961605/media/IMG-5777zpsg3jhfvzk.jpg.html
2 replies so far
View Aj2's profile
Aj2
2645 posts in 2399 days
#1 posted 07-30-2018 07:52 PM
Photo bucket sucks. If you use the lumber jock uploader it will be seen on your post. Just click on the img button and follow the path way.
-- Aj
Th961605
#2 posted 07-31-2018 04:22 AM
Thanks for the advice! Images posted.
