Miter waterfall bench joint
« back to Joinery forum
Forum topic by Newbeewood posted 07-26-2018 02:41 PM 925 views 0 times favorited 12 replies Add to Favorites Watch
View Newbeewood's profile
Newbeewood
7 posts in 547 days
07-26-2018 02:41 PM
Hello, new poster long time veiwer. I have some questions about the strength of this jointer in reference to how many people can it support. I make them appx 60”long by 16”wide by 18”tall out of 1.75” thick alder. I use 7 10/50 dominos. Anyone have personal experience with these? I would appreciate the input.
Thx
James
“What’s your next build made of”
-- Thanks, James “what’s your next build made of”
12 replies so far
View jonah's profile
jonah
2092 posts in 3906 days
#1 posted 07-26-2018 03:18 PM
With dominos or splines it’s plenty strong.
When you say “how many people it can support,” i presume you are talking about making a bench with that design.
So long as you provide some lateral stability via the dominos, you’ll be fine.
View Aj2's profile
Aj2
2650 posts in 2405 days
#2 posted 07-26-2018 03:20 PM
James just test the joint.See what it takes to break one.
Don’t you think this is better then the opinion of a bunch of strangers that probably have never built one.
I sense your concern because it a very small connection. And you never know how much weight you need to support since people come in all sizes.
The benches I make are over built for this reason.
Good luck
-- Aj
Newbeewood
7 posts in 547 days
#3 posted 07-26-2018 03:58 PM
Thx for your responses. Jonah, the more I read about the strength of domino the more I find that they might not be as strong as I think. According to some stuff I see it is only of the weaker ones. They test just one doomino and I am using 7 so I would expect it to hold but all this reading has got me wondering.
A.J. you are exactly right and that is what I am doing now. Nothin better than real testing in-house.
I had another idea last night, could I make that same miter joint and using dominos on the outside to align during glue up, then than mortise out a 10”x1/2” section on each face of the miter. Glue up the joint like normal with nothing in the mortise. Than after glue has cured drill a little hole in the seam of the inside miter and than fill the mortise with epoxy using a syringe and a needle. this maybe totally crazy but would this work? Would this make the joint really strong? Is anyone interested in seeing this tested?
Thanks again for input.
jonah
#4 posted 07-26-2018 05:57 PM
That wouldn’t appreciably increase the strength, I don’t think.
A fairly beefy wood spline would, however.
You could also add a diagonal brace, though it might compromise the look you’re going for.
View LesB's profile
LesB
2315 posts in 4050 days
#5 posted 07-26-2018 06:17 PM
If the only connection for the sides and top is the mitered joint I think you will have problems with lateral strength. I would want some sort of “stretcher between the ends and as indicated a diagonal type brace would be best. Another alternative is an apron but that might not fit the design.
-- Les B, Oregon
View AandCstyle's profile
AandCstyle
3265 posts in 2864 days
#6 posted 07-26-2018 09:34 PM
James, I used splines on one I made and it has been fine, but my son doesn’t often have people standing on his furniture. :) I also used epoxy to glue the miter. You could route out a mortise for a piece of angle aluminum and screw that to the two pieces and glue it all up with epoxy. FWIW
-- Art
Newbeewood
7 posts in 547 days
#7 posted 07-26-2018 11:04 PM
Thanks Art. I am going to try something similar and test it’s strength. I will post
My results here for anyone interested.
The first photo is using smaller dominos
This photo is my experiment which I am going to fill the mortise with epoxy after glue up.
Newbeewood
7 posts in 547 days
#8 posted 07-26-2018 11:07 PM
As for using a brace that takes away from the look that I want.
View enazle's profile
enazle
66 posts in 615 days
#9 posted 07-27-2018 12:09 AM
I once built several tables using a butterfly dovetail spline. It would be perfect for your application. You have to use a back-up when cutting the joint through the opposite end or it will blow out.
Newbeewood
7 posts in 547 days
#10 posted 07-31-2018 09:51 PM
Update. So I test my joints and I had a hard time setting up a system to try to break the joints and measure the load. So I decided to just jack up my truck and let it rest on the joint and see how long it took to break. I tested two different kinds one with two dominoes at each corner glued together with a mortise in the middle filled with epoxy. It only took 2 1/2 minutes for it to break with the epoxy. The other one was three rows of dominoes about 2 inches apart totaling 18 dominoes 12 of them were 85 The other one was three rows of dominoes about 2 inches apart totaling 18 dominoes 12 of them were 8/40 and 4 where 5/30. It took over 45 minutes for the joint to start to break apart and would never completely come apart
View PCDub's profile
PCDub
153 posts in 851 days
#11 posted 07-31-2018 10:49 PM
Wow! Impressive test! Thanks for posting your results!
Newbeewood
7 posts in 547 days
#12 posted 08-01-2018 12:48 AM
Yeah I was surprised. More dominos like finger joints as some people suggested make a very strong joint. This is how I will do my miter joints from now on. If it can hold a truck I think it should hold but to people.
