laser measuring device
Forum topic by texassteelpapa posted 07-25-2018 09:41 PM 584 views 0 times favorited 13 replies Add to Favorites Watch
View texassteelpapa's profile
texassteelpapa
27 posts in 1686 days
07-25-2018 09:41 PM
Topic tags/keywords: laser hanging
I am looking at buying a laser for hanging cabinets,trim and various uses. The last post I seen was 2011. The choice was a Stanley Fat Max. There must be better ones out there now. Any advice would be appreciated.
13 replies so far
View Ripper70's profile
Ripper70
1368 posts in 1510 days
#1 posted 07-25-2018 10:19 PM
I think the Fat Max is a standard tape measure. HD sells a full line of laser measuring devices. Bosch has a few that I’ve heard good things about. Price is dependent on the maximum measurable distance.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View bilyo's profile
bilyo
959 posts in 1704 days
#2 posted 07-26-2018 02:20 PM
Have you looked into using a water level? All it requires is a couple of dollars worth of plastic tubing and a little colored water (no batteries required :>) ). It can be just as accurate (or maybe more so) than the laser and a whole lot cheaper. I used one when I rebuilt my deck and also when I set the foundation to my shop. Works great.
texassteelpapa
#3 posted 07-26-2018 04:29 PM
bilyo, I can’t use that type of level,I work in a Clean room in a manufacturing plant and thats not possible.
texassteelpapa
#4 posted 07-26-2018 04:30 PM
fat max is a tape measure but they used to make a laser in the early 2000
bilyo
#5 posted 07-26-2018 09:47 PM
” I can’t use that type of level,I work in a Clean room in a manufacturing plant and thats not possible.”
Maybe you could use filtered water? :>)
View waho6o9's profile (online now)
waho6o9
8811 posts in 3179 days
#6 posted 07-26-2018 10:14 PM
texassteelpapa
#7 posted 07-26-2018 10:25 PM
bilyo
#8 posted 07-27-2018 01:43 AM
- texassteelpapa
Other than trying to interject a bit of humor, did I say something wrong?
Ripper70
#9 posted 07-27-2018 02:25 AM
Okay. Now I’m confused. Do you need a laser measuring device or a laser level? If for measuring see the link I posed above. If you need a level Bosch also makes one that I have that is relatively cheap and gets the job done. I used it to install long lengths of base molding.
It does need to be fairly close to the level you’re measuring as it can’t be pointed up or down to work effectively so a tripod or a ladder with the supplied clamp needs to be incorporated to use it effectively.
texassteelpapa
#10 posted 07-27-2018 02:39 AM
bilyo—No no it was hilarious , no problem sir
texassteelpapa
#11 posted 07-27-2018 02:42 AM
RIPPER—thank you ,the link was what I was looking for. I want a measuring device. Many thanks probably till I open my checkbook
View 000's profile
000
2859 posts in 1501 days
#12 posted 07-27-2018 02:53 AM
When I 1st started looking for one I just got a cheap one to see how good they were.
I’m still using it after about 4 years or so.
It’s actually very accurate.
Ripper70
#13 posted 07-27-2018 04:22 AM
- texassteelpapa
Gotcha. FWIW, Amazon sells a variety of these tools from a maker called Tacklife in a variety of capacities with budget pricing.
The user reviews are quite positive. Might be worth a closer look.
