Should I sand after a hand plain?
Forum topic by ADrapper posted 07-25-2018 01:52 AM 802 views 0 times favorited 9 replies Add to Favorites Watch
View ADrapper's profile
ADrapper
5 posts in 550 days
07-25-2018 01:52 AM
Topic tags/keywords: question oak plane finishing sanding
I am currently working with some European Oak. When I finish a piece I have planed with a nice sharp hand plane the wood looks fantastic. Glassy smooth, better than sanded wood.
But I seem to remember that before applying a finish, I should sand as a hand plain finish is too smooth. Am I miss remembering? And where do cabinet scrappers come into the picture?
Andrew
9 replies so far
View jonah's profile
jonah
2092 posts in 3907 days
#1 posted 07-25-2018 03:00 AM
If your hand plane is sharp and well-tuned, there’s absolutely no need to sand IMO.
ADrapper
5 posts in 550 days
#2 posted 07-25-2018 03:16 AM
If your hand plane is sharp and well-tuned, there s absolutely no need to sand IMO.
- jonah
Thanks. That is what I was hoping. It would be a shame to… scuff up a beautiful mirror finish.
woodbutcherbynight
6053 posts in 3017 days
#3 posted 07-25-2018 04:13 AM
No you should not. But prove it to yourself. Take 2 pieces and plane both, sand one, the other leave as is. Use a finish on it and observe results.
I asked my Grandfather same question as a kid and did the above. Saw for myself how it looked.
View TheFridge's profile
TheFridge
10859 posts in 2094 days
#4 posted 07-25-2018 05:09 AM
I’ve heard similar but have had absolutely zero problems with any finish I have tried. And if I did I’m pretty sure the shellac I use would cure adhesion problems anyway.
View ed13's profile
ed13
32 posts in 1159 days
#5 posted 07-31-2018 09:51 PM
I asked Charles Neil this once and got a very interesting answer. Sure, the planed surface is all you could ask for, but on a more complicated piece with curves, mouldings, etc., there is a lot going on. Some surfaces will have been planed, some shaped with a shave, some scraped to shape, some cut on the router, some rasped, etc. One reason for sanding can be to bring everything to an equal state. That isn’t required, but it is something to think about when composing how you want things to look. And, if you have curves that are absolutely perfect right off your spokeshave and you plan to use dye, you might want to sand end-grain like sections with a high grit to hold back the dye on those sections to keep them from going dark.
So, my answer is that planing, sanding, filing, etc., are your artists brushes. Learn how they look and compose the piece’s appearance according to what you want.
View OSU55's profile
OSU55
2507 posts in 2598 days
#6 posted 07-31-2018 11:47 PM
+1 on what ed said. Also, if you never leave a tool mark of any kind and can make an entire surface look the exactly the same with a smoothing plane, then go for it. I always find some type of minor issue when i go over the surface lightly by hand with the grain with 320, which blends everything together for the perfect finish. It doesnt take much time and its much better to find those minor things before coloring/finishing. Using a trace coat with the final sand helps find things more easily.
ADrapper
5 posts in 550 days
#7 posted 08-01-2018 04:00 AM
Thanks for all of your help and advice.
I have just do done trial peace sanded on one side and just planed on the other. Before finishing with my homemade Maloof finish the plained side looked much better, but after four Maloof poly/oil and two wax/oil, the sanded side now looks the better, just more consistent.
Thanks again.
View BalsaWood's profile
BalsaWood
172 posts in 1767 days
#8 posted 08-04-2018 06:21 AM
Thanks again.
- ADrapper
Usually they should look about the same. Once you put finish on, people can’t tell whether it was sanded or planed. Planing the piece feels better than sanding it though; no sawdust either.
View Robert's profile
Robert
3602 posts in 2089 days
#9 posted 08-04-2018 07:02 PM
I think oil finishes do better with a sanded surface, other than that, I agree.
Same with glueing: try planed vs. non planed – they stick just as well.
I find I usually have to scrape or sand a little to remove minor plane marks, although they can be left to give an old craftsman feel to a piece.
