Shelf Span
Forum topic by SpartyOn posted 07-24-2018 02:16 PM 946 views 0 times favorited 17 replies Add to Favorites Watch
View SpartyOn's profile
SpartyOn
62 posts in 3026 days
07-24-2018 02:16 PM
Question for you cabinet experts. Will a 40” wide, 20” deep shelf made out of 3/4” Baltic Birch Ply, sag over time? It seems pretty stiff and stable but don’t know if that will change over time. I know if it was a fixed shelf I could brace it such that it won’t sag. However, I’m making a cabinet for a friend that wants this shelf to be adjustable.
Thanks for any guidance!
17 replies so far
View Bill White's profile
Bill White
5308 posts in 4840 days
#1 posted 07-24-2018 02:30 PM
40” is pushing the limit. I try to keep adjustable shelves no longer than 36”.
-- [email protected]
View nkawtg's profile
nkawtg
297 posts in 2131 days
#2 posted 07-24-2018 02:32 PM
I refer you to the “Sagulator”
http://www.woodbin.com/calcs/sagulator/
View Lazyman's profile
Lazyman
5860 posts in 2267 days
#3 posted 07-24-2018 02:33 PM
A shelf 20” deep cries out for some heavy stuff on it so I would want to add support. I assume you are going to cover the edge plies? Perhaps you could use a 1-1.25” wide strip of solid wood along the front edge to add some stiffness. That might also allow you hide another strip on the bottom as well make it even more rigid, depending upon how high it is of course.
View BurlyBob's profile
BurlyBob
7938 posts in 3145 days
#4 posted 07-24-2018 03:27 PM
I agree with Bill and Nathan. I’m thinking it might work with a serious strip across the front like Nathan suggest. Also besides shelf pins on the sides, shelf pins in 2 locations on the back side.
SpartyOn
#5 posted 07-24-2018 08:55 PM
- nkawtg
That’s a very helpful site. Thanks!
SpartyOn
#6 posted 07-24-2018 08:57 PM
- Lazyman
I do plan on adding a hardwood edge. Didn’t think about how that will help. Great idea an making a bit wider and hiding an additional strip on the bottom. Thank you!
SpartyOn
#7 posted 07-24-2018 08:58 PM
I agree with Bill and Nathan. I m thinking it might work with a serious strip across the front like Nathan suggest. Also besides shelf pins on the sides, shelf pins in 2 locations on the back side.
- BurlyBob
Another good thought! Thank you!
SpartyOn
#8 posted 07-24-2018 08:59 PM
- Bill White
Good input! Thanks, Bill.
View DS's profile
DS
3571 posts in 3300 days
#9 posted 07-24-2018 09:16 PM
View AandCstyle's profile
AandCstyle
3287 posts in 3137 days
#10 posted 07-24-2018 09:18 PM
Sparty, you can also put a lip on the back edge if necessary for the added strength or ONLY put a lip on the back if you want the design to appear more open or lighter. FWIW
-- Art
View Redoak49's profile
Redoak49
4915 posts in 2868 days
#11 posted 07-24-2018 10:19 PM
Yes, a front and back edge strip. I over build everything and would cut at least one dado in the bottom and add a strip in the middle.
I would ask what was going on the shelf and over build it.
woodbutcherbynight
6286 posts in 3289 days
#12 posted 07-25-2018 01:21 AM
Definitely want to know what is going on the shelf. Then double that, cause overbuilding is okay!
View Richard's profile
Richard
11310 posts in 3913 days
#13 posted 07-25-2018 01:45 AM
- AandCstyle
This is Okay also!
Rick
-- Richard (Ontario, CANADA)
View PPK's profile
PPK
1802 posts in 1689 days
#14 posted 07-25-2018 02:00 PM
That’s a big shelf. I don’t know that I’d completely trust the “sagulator”... it’s pretty cool… but awful scientific for something very unpredictable like WOOD! It’s kind of like trying to predict the springback on a steam bent peice of wood. You can calculate till you go cross eyed, and depending on the specific board you bend, it will NOT comply with all that calculating :-)
Anyway, I’ve built lots of big cabinet shelves, and if you put edging on the F and B, you’ll be fine. Baltic Birch is a very good plywood. If you were using particle board or MDF it’d be an entirely different story though!
-- Pete
SpartyOn
#15 posted 07-25-2018 05:26 PM
Thanks everyone for the help! I knew I could count on this group!
