What kind of router bit do I need?
Forum topic by AdrJunkie posted 07-23-2018 05:11 PM 900 views 0 times favorited 17 replies Add to Favorites Watch
View AdrJunkie's profile
AdrJunkie
5 posts in 822 days
07-23-2018 05:11 PM
Topic tags/keywords: router oak question
I am trying to build a cabinet to match my existing cabinets. I have it all taken care of except the drawer pull. I’m not sure what kind of bit this would be, or if it’s more than one. The routed edge is close to 1” wide. I can only find raised panel ogee bits that wide. Thanks in advance
17 replies so far
View DS's profile
DS
3571 posts in 3300 days
#1 posted 07-23-2018 05:26 PM
This was most likely made with a custom shaper head.
You will be hard pressed to find this in a router bit.
If you do find it, expect that it will not be inexpensive. ($85 to $100 range)
https://www.amanatool.com/products/router-bits/profiling-router-bits/table-edge-router-bits.html
For a single drawer front you could use a series of cuts using more common bits, and/or your tablesaw , to achieve the fundamental profile.
Don’t underestimate the value of a course sanding block in finalizing the profile.
Thinking completely ‘out-of-the-box’, you could attempt to discover the original manufacturer and pay them to make another front for you. It might be cheaper than trying to tool up for one front.
View Gene Howe's profile
Gene Howe
12258 posts in 4308 days
#2 posted 07-23-2018 05:33 PM
Use a table saw…carefully.
AdrJunkie
5 posts in 822 days
#3 posted 07-23-2018 05:46 PM
I appreciate the responses. I figured this was a custom piece and I’ve searched every cabinet for a manufacturer with no luck. I’ll try a couple of techniques out on a scrap piece and see if I can get it close enough.
We just moved a few weeks ago and I’m sure I’ll be refacing them before too long. Just need something to blend in until then
View CaptainKlutz's profile
CaptainKlutz
3709 posts in 2374 days
#4 posted 07-23-2018 05:59 PM
This looks like a traditional or thumb nail table edge profile. Largest sizes typically can have 1 inch cut width.
Whiteside, Amana, and Eagle all have bits with similar profile?
Best Luck.
View DS's profile
DS
#5 posted 07-23-2018 06:10 PM
Possible candidate?
https://www.whitesiderouterbits.com/collections/door-edge-bits-front-face/products/6020
View bonesbr549's profile
bonesbr549
1588 posts in 3947 days
#6 posted 07-23-2018 06:22 PM
Use a combination of a round over bit and a hand plane.
Here is kinda an example
https://youtu.be/yTiPoHNU8zA
good old stumpy nubs :)
Gene Howe
#7 posted 07-24-2018 11:52 AM
Still think a table saw is quicker and easier.
View EarlS's profile
EarlS
4003 posts in 3228 days
#8 posted 07-24-2018 12:04 PM
Take a look at MLCS. They have a large selection of profile bits.
View theart's profile
theart
229 posts in 1434 days
#9 posted 07-24-2018 12:58 PM
View Lazyman's profile
Lazyman
5860 posts in 2267 days
#10 posted 07-24-2018 03:17 PM
Is it profile A or C perhaps of these Euro style door edge bits?
https://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_door.html
EDIT: And if that doesn’t work, try searching “cabinet edge profiles” in google and select images. That may help you visually find similar profiles.
AdrJunkie
5 posts in 822 days
#11 posted 07-24-2018 03:20 PM
I did find a bit from amana. It’s a 2.5” D. Looks pretty close. It’s $76 on toolstoday.com. I think I’ll still try the round over and table saw on a scrap piece first. Hopefully I can pull it off and save some cash
Lazyman
#12 posted 07-24-2018 03:37 PM
Those MLC bits are only listed at $21 on their website if they are the right profile.
AdrJunkie
5 posts in 822 days
#13 posted 07-24-2018 05:11 PM
- Lazyman
Profile C looks pretty close. I think I’ll order one at that price. Thanks Lazyman
View BurlyBob's profile
BurlyBob
7938 posts in 3145 days
#14 posted 07-24-2018 07:49 PM
I agree with the Capt about it being a thumb nail table edge profile.
AdrJunkie
5 posts in 822 days
#15 posted 07-24-2018 09:54 PM
Best Luck.
- CaptainKlutz
- BurlyBob
That’s what I’ve been searching for. I actually just found one on MLCS that looks like the candidate. It’s a thumbnail with a 1 1/8” cut which is what mine is. https://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bit_table_edge.html#455
