Drawbore in Yellow Pine?
« back to Joinery forum
Forum topic by Lsmith3023 posted 07-14-2018 12:37 AM 1249 views 0 times favorited 4 replies Add to Favorites Watch
View Lsmith3023's profile
Lsmith3023
17 posts in 803 days
07-14-2018 12:37 AM
I am trying something new. I’m building a farmhouse table for my Daughter-in-law. I have glued up the top and I am going to breadboard the ends.
I would like to drawbore the Mortise joints but I have been seeing conflicting information on whether it would be a good idea or not. I know i’m working in softwood but will the drawbore add any strength to the joint or should I just rely on the M&T and glue? I am using a Tongue and groove the length of the end and cutting tenons beyond that
View bondogaposis's profile (online now)
bondogaposis
5803 posts in 3153 days
#1 posted 07-14-2018 01:24 AM
Draw boring in pine is likely to split the breadboard. If you do it, make the offset very slight. Don’t glue the whole length of the breadboard, just the center.
-- Bondo Gaposis
View JADobson's profile
JADobson
1448 posts in 2913 days
#2 posted 07-14-2018 03:49 AM
I’ve done plenty of drawbores in pine. They work fine. This one is in a leg but I’ve done them in breadboards too. The farmhouse table in my projects has drawbored breadboards.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
View Pat3's profile
Pat3
145 posts in 2681 days
#3 posted 07-14-2018 04:47 AM
I am also in the middle of making a farm table for my daughter, using Port Orford Cedar, which is a very soft wood. I drawbored and wedged M&T the feet to the legs, end braces to the legs and the stretcher to the legs.
There were no issues with the drawboring.
I will also be drawboring the bread board ends for my top as well, and I do not expect any problems with those joints.
View Robert's profile
Robert
3786 posts in 2283 days
#4 posted 07-14-2018 01:29 PM
Draw boring is a timber frame technique that has applications in ww’ing, especially joinery where glue cannot be used.
For that reason, they are necessary in a breadboards. Simply pinning a bb end will risk loosening as shrinkage or movement occurs. Keeping the pins with 3/4” or so of the edge minimizes gaps from shrinkage.
You can certainly drawbore soft wood you just have to be very careful not to over do the offset (no more than 1/32’).
If you’re mortises are well fitted, drawboring has no advantage over gluing and pinning. Pinning a tenon adds trememdous strength.
While I’m thinking about it, be sure that yellow pine is dry and well acclimated!!
