Help creating an old crown moulding profile
Forum topic by Lewellen posted 07-13-2018 05:45 PM 516 views 0 times favorited 6 replies Add to Favorites Watch
View Lewellen's profile
Lewellen
3 posts in 554 days
07-13-2018 05:45 PM
Hi everyone! I need help! I need to duplicate a crown moulding profile that is obsolete and no longer sold in Lowe’s or Home Depot. I have sent a photobucket link for the profile pic of the moulding. I work with wood a lot (framing, construction etc) but I am a COMPLETE noob when it comes to router tables and/or shaper tables. The dimensions are 5/8th” front to back, and 1 3/4” top to bottom. My question is which router bits do I use to get this profile? I hope I explained this correctly. The following is the link for the pic. Thanks for any help. http://i145.photobucket.com/albums/r234/trickshot63/GEDC1099_zps8ajp6yeo.jpg
View John Smith's profile
John Smith
2128 posts in 764 days
#1 posted 07-13-2018 06:33 PM
how many linear feet do you need ?
-- I am a painter. That's what I do. I paint things --
MrUnix
7579 posts in 2800 days
#2 posted 07-13-2018 06:48 PM
Looks like you could get by with a standard roman ogee bit with some minimal sanding to round-over the sharp edges if needed.
View CaptainKlutz's profile
CaptainKlutz
2208 posts in 2096 days
#3 posted 07-13-2018 08:11 PM
+1 Brad’s comments – looks like conventional roman ogee?
In case it is not obvious to you:
If you need larger flat area ‘on top’ than single bit creates, then make several passes; pushing the bit up each time to create wider edge.
Do not forget to cut the back side relief into the molding. You need to allow for variations in wall corner joint behind where molding mounts. May also find it easier to cut the relief on table saw before you cut the profile, as it is typically easier to hold ‘odd’ shapes against router fence than table saw fence.
Best Luck
Lewellen
3 posts in 554 days
#4 posted 07-13-2018 08:51 PM
Thanks guys! Only need about 4 feet Mr. John Smith
Lewellen
3 posts in 554 days
#5 posted 07-13-2018 09:24 PM
MrUnix, there is a 5/32 and a 1/4 at Lowe’s. Which should I get? The 1/4?
View 000's profile
000
2859 posts in 1501 days
#6 posted 07-14-2018 02:10 AM
This is the quickest, easiest and smartest way to build the project you desire.
https://tinyurl.com/y8gkg6vz
- kjalal
Teds plans..don’t open
