Leg Fabrication
Forum topic by MrRon posted 07-10-2018 05:17 PM 410 views 0 times favorited 11 replies Add to Favorites Watch
View MrRon's profile
MrRon
5812 posts in 3853 days
07-10-2018 05:17 PM
The sketch shows a proposed leg fabrication; it is for a small workbench I’m building. I want to rip the 1×2’s from 2x stock, but I know that it will not be straight once ripped from the mother board. Is there a way to maintain straightness, or will the legs remain straight once glued up?
11 replies so far
View pintodeluxe's profile
pintodeluxe
6040 posts in 3422 days
#1 posted 07-10-2018 06:02 PM
Wow, I don’t understand this at all. Why are you gluing that from four pieces, and what’s with the rabbets? More info please.
View Woodknack's profile
Woodknack
13022 posts in 2989 days
#2 posted 07-10-2018 06:05 PM
You’ll generally get better stock from a 2×12 than a 2×8, let it dry a nice long time and there shouldnt be much movement when you cut it. A little bow won’t hurt anything, the box construction of the leg will pull it out.
MrRon
#3 posted 07-10-2018 06:35 PM
Wow, I don t understand this at all. Why are you gluing that from four pieces, and what s with the rabbets? More info please.
- pintodeluxe
The rabbets are for the front, back and side panels of the bench; all of which are 3/4” thick. This is the only way I can get the 2-1/4” dimension I want. I intend to rip 3/4” wide strips from 2×12 lumber and glue them up as shown. Once glued, I will then cut the 3/4” wide by 3/8” deep dado’s to accept the 3/4” panels. I hope this explanation is clear.
MrRon
#4 posted 07-10-2018 06:42 PM
You ll generally get better stock from a 2×12 than a 2×8, let it dry a nice long time and there shouldnt be much movement when you cut it. A little bow won t hurt anything, the box construction of the leg will pull it out.
- Woodknack
Thanks for the tip. I will use a 2×12. A 10’ long piece of 2×12 will supply all I need for 4 legs. As I mentioned before, this is for a small workbench that will be used for hobby use, like building models, not for heavy pounding on. Once done, it will probably go into the house and sit in a corner. All heavy woodworking is done outside in my 1200 sf shop.
pintodeluxe
#5 posted 07-10-2018 06:42 PM
Okay, so the rabbets won’t be there during the glueup phase, OK I follow now.
Yeah I wouldn’t do it that way. Just glue boards together face-to-face to get your required thickness. This will give you a solid leg. Then cut the joinery afterwords.
If you make the parts a little oversize, you can re-joint things straight and square after glueup.
View RobHannon's profile
RobHannon
330 posts in 1140 days
#6 posted 07-10-2018 06:58 PM
I agree with pintodelux on face gluing it up, but if you need to do the 4 piece glueup for the hollow core keep in mind that construction grade lumber is often dried fast and has internal stresses. You may need to mill it over-sized and let it acclimate.
Any reason you cant use 3/4 plywood?
View bondogaposis's profile
bondogaposis
5607 posts in 2960 days
#7 posted 07-10-2018 07:02 PM
Since all of the pieces are 3/4” why not make from 3/4” stock?
-- Bondo Gaposis
View waho6o9's profile
waho6o9
8812 posts in 3186 days
#8 posted 07-10-2018 08:20 PM
Bondo +1
3/4 FAS ( First and Second ) graded stock and you’re good to go.
Alder seems to be the crowd favorite.
View HokieKen's profile
HokieKen
12010 posts in 1748 days
#9 posted 07-10-2018 08:25 PM
I was actually wondering about 3/4” plywood. Nice and straight and stable.
-- Kenny, SW VA, Go Hokies!!!
View PPK's profile
PPK
1641 posts in 1419 days
#10 posted 07-10-2018 08:43 PM
Just another thought: Cut down a 4×4 to size is an option, no?
-- Pete
MrRon
#11 posted 07-10-2018 08:46 PM
I agree that face gluing up 3/4” stock would be a better way and easier way to do it. I can use 1×3’s, rip them down on both edges to 2-1/4” wide, then glue 3 of them together or glue first and then rip. I can see they will come out straighter. Plywood is also a good option. Thank you all.
