Aluminum Jig Bar - Solved
Forum topic by BroncoBrian posted 07-10-2018 02:13 AM 1313 views 0 times favorited 16 replies Add to Favorites Watch
View BroncoBrian's profile
BroncoBrian
875 posts in 2562 days
07-10-2018 02:13 AM
I have a pair of Kreg bars that I am about to use for a crosscut sled. But like an idiot, I waiting long enough to use them and they made a trip to the floor.
I have two small depressions on the corners of each. I can take a file to the bar or trim an inch off.
Which would you do?
-- A severed foot is the ultimate stocking stuffer.
16 replies so far
BroncoBrian
#1 posted 07-10-2018 02:13 AM
Same question I guess for the T Track I bought as well. Need to cut to length.
View patcollins's profile
patcollins
1687 posts in 3468 days
#2 posted 07-10-2018 02:14 AM
just take a file to the bar, aluminum files pretty quickly.
View bondogaposis's profile
bondogaposis
5604 posts in 2954 days
#3 posted 07-10-2018 02:18 AM
File it.
-- Bondo Gaposis
BroncoBrian
#4 posted 07-10-2018 02:29 AM
Thanks, and yes, that was much simpler than I expected. It filed very easily and I have a nice even bevel on each end now on all sides. Looks good.
Thanks!
View John Smith's profile (online now)
John Smith
2131 posts in 766 days
#5 posted 07-10-2018 02:47 AM
you would be surprised at how many people actually cut aluminum stock
on their regular ole wood cutting miter saw and table saw.
-- I am a painter. That's what I do. I paint things --
View Joe Lyddon's profile
Joe Lyddon
10859 posts in 4655 days
#6 posted 07-10-2018 03:54 AM
- John Smith
YES!!
I’ve seen where people will change the TS blade to another blade and use it to cut aluminum… Cut slowly… and tidy the cut with a file to remove the sharp edges…
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: https://www.ncwoodworker.net/forums/index.php
View bbasiaga's profile
bbasiaga
1243 posts in 2598 days
#7 posted 07-10-2018 11:13 AM
That is the nice thing about aluminum, W/o us wood blades will cut it. They do dull faster, obviously. But if you have a band saw you can get a metal cutting blade for it and that keeps an edge better.
Brian
John Smith
#8 posted 07-10-2018 12:06 PM
I have never put a metal cutting blade on my M/S or T/S to cut aluminum.
I have used the same 12”x80T blade on my Dewalt M/S for years and cut
a lot of aluminum stock. Being a signmaker, I use a lot of aluminum forms
for bracing and framing sign material. Plus a lot for my aluminum boat stuff.
of course it is Your Saw = Your Call. just be SAFE about it.
View pontic's profile
pontic
714 posts in 1212 days
#9 posted 07-10-2018 12:11 PM
If it’s a carbide tipped blade it will cut that Kreg stock with ease.
-- Illigitimii non carburundum sum
View hairy's profile
hairy
3004 posts in 4135 days
#10 posted 07-10-2018 12:14 PM
If it s a carbide tipped blade it will cut that Kreg stock with ease.
- pontic
You got that right!
-- Genghis Khan and his brother Don, couldn't keep on keeping on...
View MrRon's profile
MrRon
5810 posts in 3847 days
#11 posted 07-10-2018 08:25 PM
I used to cut aluminum with my wood cutting blade, but I recently got an aluminum cutting blade and it works way better. The only difference is the aluminum blade has negative rake on the teeth as opposed to a positive rake on the wood cutting blade, but for a one off cut, the wood blade will work. Make sure you wear eye protection as the chips are hot
patcollins
#12 posted 07-11-2018 12:53 AM
I wouldn’t use a high ATB blade just for the faster dulling properties of aluminum vs wood, but flat tooth or TCG grind have at it.
My biggest worry is the electrically conductive and highly abrasive chips being in the saws moving and electrical parts.
View corelz125's profile
corelz125
986 posts in 1579 days
#13 posted 07-11-2018 12:54 AM
Can always go to the old reliable hacksaw or metal blade on a sawzall
MrUnix
7582 posts in 2802 days
#14 posted 07-11-2018 01:03 AM
I keep an old carbide tipped circular saw blade handy for cutting non-ferrous metals, just so I don’t trash a good blade. I also reduce the speed of the saw to around 1/2 to 2/3 of full speed, which helps as well.
View jonah's profile
jonah
2092 posts in 3902 days
#15 posted 07-11-2018 12:52 PM
Any carbide-tipped saw blade will cut aluminum quite easily. Sure, it’ll dull a bit faster, but if it’s just two bars that’s not an issue. I’ve cut plenty of aluminum on my miter and table saws.
