Sticking Cork- tiles
Forum topic by EdsCustomWoodCrafts posted 07-09-2018 04:49 PM 491 views 0 times favorited 8 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
932 posts in 1944 days
07-09-2018 04:49 PM
Hey everyone
I have been working on a office room divider and on one of the sides I want to add a cork-board surface (12”x12” tiles) but I am not sure how to stick them permanently should I use
A. Contact spray adhesive
B. Regular wood glue like Titebond II
C. Other method
Project picture
I will be adding the cork-tiles to this panel
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown” . Come check out my website for more about what I make and how at www.edscustomwoodcrafts.com
8 replies so far
View LesB's profile
LesB
2297 posts in 4044 days
#1 posted 07-09-2018 05:25 PM
Contact cement, spray on or brush, follow instructions carefully. Use caution when placing the panels. The slightest touch between the two surfaces and that is where the piece will stay.
-- Les B, Oregon
View splintergroup's profile
splintergroup
3193 posts in 1823 days
#2 posted 07-09-2018 07:00 PM
I’d use 3M “super 77” spray. Just follow directions.
View Grandpa's profile
Grandpa
3263 posts in 3276 days
#3 posted 07-09-2018 08:14 PM
I think any good contact adhesive should work fine. I recently put some cork tile together making a stack that is 1” thick. I used some adhesive I had left from a Formica job. LesB is correct. Where it lands it stays
View Megalos's profile
Megalos
2 posts in 598 days
#4 posted 07-10-2018 06:01 PM
Cork can suck up a good portion of the first coating of contact cement. You may want to add a second after the first one feels dry to the touch.
EdsCustomWoodCrafts
#5 posted 07-10-2018 06:04 PM
Thanks everyone that chimed in with some advice I think I’m going to use 3M 90 extra gold spray contact adhesive
View pintodeluxe's profile
pintodeluxe
6032 posts in 3414 days
#6 posted 07-10-2018 06:05 PM
I just used spray adhesive to attach cork rolls, and it worked fine. I used 3M High Strength 90 in the green can.
EdsCustomWoodCrafts
#7 posted 07-10-2018 06:26 PM
- pintodeluxe
Glad to hear that I think that’s what I will use .. someone else recommended 3M 77 what’s the difference ??
splintergroup
#8 posted 07-10-2018 06:49 PM
- pintodeluxe
- EdsCustomWoodCrafts
Strength. Higher number = higher bond strength.
